pamcopete
Ride.Enjoy.Life is Simple
Upon adjusting it by moving pamco disco it ran good . But when i turn it back on it is all miss firing and wont respond to throttle.
The ignition is simple. It provides a spark at the "F" mark at idle and at the full advance mark at 3200 RPM and beyond. If you tested for these two conditions with a strobe light and still have problems, then it is most likely not the ignition.
I think you started this thread by saying that you were going to install a PMA with a capacitor? If that is the case, the try disconnecting the PMA and the capacitor and temporarily wire the PAMCO and coil to a separate, stand alone battery. This test will help to determine if the problem is the PMA.
