bt24
New Champion copy Yamaha 750 Twin for sale.
Fresh build, only break in time on new engine build, almost everything on this build is brand new.
$7,800. OBO plus shipping.
No trades, Possible delivery.
New Champion Yamaha XS750 Build/Parts sheet
New Chromoly tubing frame built in a Champion XS Yamaha Frame Jig.
New Tapered Steering Head Bearings
Rebuilt GSXR 750 forks & Triple clamps
New Vortex Johnny Murphree bend 1" taper bars
New Pro Taper Bar Risers
New Pro Taper grips
New Motion Pro Turbo Throttle
New Motion Pro 2 into 1 Throttle Cable
New Kill Button
New MSR Adjust on fly Clutch & Perch
New Clutch Cable
Works Rear Shocks 1/2 season old
New Excel Wheels 2.50X19" Front/ 2.50X19" Rear
New HD Stainless Spokes Front & Rear
New Maxxis Tires Front & Rear
New Barnes Hub Front
New Barnes Hub Knock Off Rear
New Streamline rear disc with New billit aluminum carrier
Nissin Brake Caliper with New Brake Pads
New Stainless Steel Braided Brake line
New Stainless Brake fitting
New Nissin Master Cycinder
New Billit Brake Pedal
New Billit Brake Ped/Mastr Cyl plate
New 520QR Tsubaki Chain
New Billit Axcel/Chain Adjusters
New Rear Axcel
New Swingarm bolt/bearings
New First Klass/Bates foot peg rubbers
New foot peg blades & mounts
New 750 Fiberglass Tank & Seatbase w/ Seat
New 90 degree K&L Fuel Petcocks w/New fuel line
New Engine parts list
New Billit Cam Covers
New Nuts & Bolts
New Billit Engine Mounts
New All Gaskets
New All Seals
New Reed Type PVC Valve Engine Breather
New Oil and Lower Oil Sump Filters
New Axcel 8.8 Coil Wires/Caps
New PVL Ignition and Coils
Norris 1/2 Mile Cam
New Tsubaki Cam Chain
New Cam Chain Guide
New Cam Chain Tensioner Pivot Arm Assembly
New EBC Clutch Plates Steel & Fiber
New HD Clutch Springs W/Allen bolts, aluminum spacers
New Clutch Thrust Bearings & Nuts
New Clutch Long Pushrod w/ Bearing
New Clutch Push Housing Assembly
New Kibblewhite Racing Springs w/Titanium Tops
New Wiesco Yamaha 750 Piston kit
New LA Sleeves
New RD 1mm over Exhaust Valves
New RD 1mm over Intake Valves
New Bronze Valve Guides
New 3 angle cut valve job
New hand ported Intake & Exhaust Head
New (2) 38mm Mikuni Round Slide Carbs
New (2) Billit carb Intakes
Jemco High Exhaust (Ceramic Coated)
New (2) K&N Air Filters
Stock Rods, Crank Bearings, Oil Pump, everything was checked for wear and runout.
Bryan Trippe
bryantrippe@msn.com
Albuquerque, NM. 87124
Cell: 505-400-7244
