So, I finally did some work on the RustBucket.
This is what I worked on. That first pic was just a teaser/reminder of the patina that I'm working with. I intend to do the absolute minimum aesthetic-wise on this bike. But, since it is almost 100% complete and intact, I at least want to repair the "Swoosh" trim on the right-side cover. How I fixed a broken Swoosh, with way too much detail and way too many pictures follows.
First, let's back up and explain why it has taken me so long to do anything on this project. I began the Bonded Title application way back in the very beginning of December, 2020. Texas has been progressively making it harder and harder to get bonded titles for years. It used to be that if the state had no records of your VIN, all you had to do was go to any vehicle inspection station (there are thousands of them), and get the inspector there to visually verify your VIN. But, now, you have to go to the Sherrif's Combined Auto Theft Task Force to get your VIN verified. Each county has only one of these locations.
Well, even though the RustBucket is a Texas bike, it has been so long since it was last registered, that it pre-dates computer records. In other words, the state had no records of the VIN, so I had to go to the County Sheriff. This is a hoop that I have never had to jump through before, and I've probably gotten about 20 Texas Bonded Titles.
I applied at the beginning of December for an inspection appointment. Finally got an appointment for the end of December. Then, two days before my appointment, it was cancelled due to COVID. That inspection moratorium lasted FOUR months. The Sheriff's finally resumed inspections two days ago. I now finally have all of my bonded title paper work. I just have to pay the usual registration and taxes -- my appointment for doing that is three weeks from now.
In any case, my bike is green-lit, it isn't stolen, so I'm finally working on it.
No, I don't have a way to replace that big chunk of missing "Swoosh" from the RustBucket's right-side cover. But, I am able to repair plastic cracks and plastic mounting posts. Some time ago, I was removing a swoosh from a different side cover. I was prying off the little round "push-nuts" on the posts with an angled pick. This is a fine procedure if your badge or emblem is metal. However, never, EVER pry off push-nuts from a plastic trim piece. Don't do it! Especially when the plastic is 50 years old! The only safe way to get them off is to cut them off with a Dremel cut-off wheel. And, you want to do this with plenty of cooling water present so that you don't melt the plastic post. It's probably a good idea to make sure the Dremel is on a GFI protected circuit.
So, as I'm sure you've guessed, using the angled pick tool, I broke a mounting post. I should have taken a picture before I began the repair, but I didn't.
Not only did the post break, but the tip of the swoosh cracked. It is just barely hanging on by a thread.
Now, at this point, there are two ways to proceed. One way would be to mount the Swoosh using the good posts, and simply gluing the cracked section directly to the side cover. This would be the Easy Way. But, it wouldn't be the Cowboy Way. I like to explore what is possible, so I chose to see if I could replace the post and repair the crack.
I found this minuscule screw in my Big Bin O' Tiny Nuts and Bolts, and I cut the head off of it.
Intact posts are hollow, as you can see from the post on the right. There was enough of that hole left for me to insert the screw after I enlarged the hole a little. I know had a perfectly centered new post that was stable enough to apply Epoxy. I also added a piece of glass cloth to reinforce the crack in the Swoosh. The glass cloth is over-sized so that I can handle it. It will be trimmed after the epoxy sets.
I think my original idea was to use a nut of some sort, maybe a tiny speed nut, on the tiny screw, but I didn't think I would ever find anything that small that would work, so the plan changed.
This is what I like. I used it plain and runny on the glass cloth. I needed to thicken it on the post repair, so I added the 405 filler. BTW, the West System is specifically designed for wooden boats, so their various fillers all turn the clear epoxy brown, or wood-colored.
The almost-finished post after a second application of epoxy. The epoxy was thickened, but still runny enough to shape itself to the screw with surface tension. I had to periodically flip the piece upside-down while the epoxy set to get it to stay where I wanted it, because it ran just a bit.
I've done a bit of final trimming using an abrasive Dremel bit.
Almost done. I still had to do a little bit of final Dremeling while fitting the new push-nut.
https://www.amazon.com/gp/product/B07M6JPG68/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Onward to the push-nuts, AKA starlock washers, AKA internal tooth washers, AKA push-on speed clips, etc., etc. There are lots of fairly spendy options for these, but I foresee a lot of Swoosh and other emblem fastening in my future, so I bought these. 100 pieces for $7.
Problem is, these are advertised as M4, but I don't know how the heck they are measuring them -- they are way too small for an M4 stud, or screw, or rod, or post.
https://www.amazon.com/gp/product/B07JD8H2DX/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
So, I went up to these M5 starlocks. These were specifically advertised as having a 4.3mm I.D. Again, I don't know how the heck they are measuring them, but the I.D. was a lot bigger than 4.3mm , and these were unusable. I got my money back from Amazon, got to keep them, and I went back to the M4 starlocks that I bought the first time.
The trick now was to enlarge the I.D.s of those M4 push-nuts using the Fred Flintstone Tool Kit available to me.
Using a drill bit as a holder...
... I chucked them up into a BFDM.
https://www.harborfreight.com/titanium-high-speed-steel-numbered-drill-bit-set-60-pc-61690.html
And I incrementally enlarged the I.D. using a second drill motor and the above Harbor Freight numbered drill bit set, a marvelous bit of kit that I don't know how I ever got along without.
This was pretty tedious. Thank goodness for quick-change key-less drill chucks.
The factory put little rubber "gaskets" under the push-nuts. I made new cork-rubber gaskets using my old gasket cutter.
https://www.amazon.com/Mayhew-66002-8-Inch-2-Inch-Imperial/dp/B000X35UQ8
My gasket cutter kit is a knock off of this one. I bought it way, way back, in order to make the gaskets for my ThermoDipSticks. The mandrel can hold two different cutters at the same time, so you can cut a complete circular gasket in a single step. I think I only paid $60 for my kit. I haven't seen the knock-offs offered for sale in years.
Repaired post at the bottom, Swoosh installed with all new push-nuts and gaskets.
All better now.
Another view.
The little crack.
The fitment gap is exaggerated in this enlarged picture. It's good enough for the RustBucket, and I did it the Cowboy Way.
