Tool for the fork inside
Taking this from memory so perhaps I remember wrong but something in this direction
a piece of pipe
a piece of all thread rod inside that pipe
3 nuts.
Lower end that goes inside the pipe double nut tightened against each other Standard nut that has the right dimensions was it 17 mm
Upper end one single nut tightening the alt thread and lower 2 nuts to / against the pipe.
With that I was able to loosen and tightening ..
Should it not work a little weld can solve it . I never needed it
The hardware is easy to find here and can be in house many times
The pipe I got from a shop nearby.
a piece of pipe
3 nuts.
