Aftermarket Rear Sets
1981special
Salem, OR
Hello all, I’m new to this forum and have 1981 xs650. When I got the bike the shifter wasn’t on the bike, nor was the rear brake linkage. He gave me the parts but said something about welding a bracket to the frame in order for them to work.
I finally got them bolted down without needing to weld anything but when I shift the bike the clutch lever is very firm and the shifter just rotates. The bike doesn’t shift but the whole shifter rotates. Also I haven’t got the rear brake connected yet. If you know anything I’d love to hear some advice!
Welcome!
Some pics can likely help, if possible. Most rear-sets come with their own pedals rather than using stock versions.
I hoping you don't mean the shift shaft (splined rod entering motor) is rotating > a fraction of a turn. ?
Welcome!
I will take some pictures soon. Even though I tightened the bracket that connects to the shift shaft. The bracket rotates around the splines. The splines are either toast or the bracket that bolts on to it is.
I know this picture doesn’t do much but the stud to tighten down the shifter itself is stripped so now I have another issue on my hands. When the shifter is tightened down all the way the shift shaft bracket rotated but now that the stud is stripped it obviously won’t stat in one place. This bike hasn’t been ran in 30 years and I got it running but now I need to get it ready to drive. I have the original shifter that I could throw on for now. Any advice on how to get it off? It seems wedged on there.
The only advice I can offer is to stay far away from Raask rear sets. I bought a set years ago and still use it. It took months for the buyer's remorse and resentment to fade.
One linkage rod end was pressed into to the wrong side of the shift shaft collar tab, rendering the shifter inoperable. Thorstein must have been working off the weekend's mead when he did that. The material is pot metal and very brittle. My shift pedal is now held together with screws and mending plates. I overpaid once for the set and would rather live with a cosmetic flaw than be robbed again by paying a premium price for a substandard item.
Is it that one we are talking about
The chromed parts rotates but not the shift axle
Threads stripped for the black bolt.
Use another bolt all the way trough perhaps smaller diameter and a nut ...washer
Possible stronger grade on the screw
Then you can apply large clamping force -- have done it on the stock shift pedal
Check so that nothing prevents the clamping gap I Have opened the gap with a cutting disk sometimes
if do that ...eventually the pedal will break at the clamping region . Or not.
To remove the arm on the shifter shaft, file or grind off the bolt head, and try to tap out the remaining piece, or just drill the whole clamping bolt out with a 1/4" bit..
Then reassemble with a longer M6 bolt with a nut. If the gap closes completely when tightening, use a hacksaw to siden the gap slightly.
Then adjust the linkage rod so that it is perpendicular to the shifter arm.
That should improve shifting a lot.
Just basic force and levers, like the ancient Greek already had figured out. And most likely the Egyptians before that.......
Sadly, as Jim points out, the factory lower footpeg mount has been hacked; that's gonna be the "welding" the PO eluded to. Will not work that way. If you decide to proceed with welding, first remove or disconnect all electrical boxes, coils and isolate all frame grounds from electrical system.
Suggest perhaps consider stock pegs or other rear-sets.
The angles on this set up are all wrong. The splined connector to the shift shaft works better when its parallel to the actuator on the foot lever.
The link shaft from the lever to the splined connector is too short to allow the parallel motion.
Here is a picture of my Cognito Set-up (Its expensive), there are cheaper alternatives but the implementation would be the same.
View attachment 222265View attachment 222267
HI, Adam, how is the comfort with these sets?
The set up is fully adjustable, so comfort is excellent.
My set up is a bit custom here but the principle is the same regardless.
Cognito Moto have a standard set up for the standard XS frame.
Just check their website
You are welcome to ask me more anytime.
i am suspecting that the fairly forward position of the stock pegs is actually less comfortable than something similar to these rear sets, that is shifted backward compared to stock. There are some articles on the web to support this theory. Two bikes that i found comfortable: R1100GS and buell M2 had pegs that were positioned signficantly more backwards than the XS.
We have a member who sells "rear sets" in the classified and I will vouch for the value he offers, I took his kit and modified it to fit my needs. I moved pegs forward and down from the original suppliers design. My bike feels like an enduro with pegs under my body mass. This pic illustrates where I like pegs. Look up "rearsets" in classiffieds and you will find the member/ Again, he supplies a quality product at good value. My needs sent me to re-engineer some of the fitment...
We have a member who sells "rear sets" in the classified and I will vouch for the value he offers, I took his kit and modified it to fit my needs. I moved pegs forward and down from the original suppliers design. My bike feels like an enduro with pegs under my body mass. This pic illustrates where I like pegs. Look up "rearsets" in classiffieds and you will find the member/ Again, he supplies a quality product at good value. My needs sent me to re-engineer some of the fitment... View attachment 352784
yes, this sort of lower and backwards is that I am thinking about. How do you like it? how long can you ride until you are uncomfortable?
