Thanks retired,
I plan on taking the carbs apart, however I have not owned the bike 48 hours yet so have not had the time to remove carbs and take them apart and rebuild. also no point in doing it until I have a carb kit in hand to put them back together. Normally I would disregard what the PO said however he seems to be a very meticulous type judging by the cleanliness of the bike and the detailed notes he left in the manual about work he had done to the bike. But yes, I am going to listen to your advice and take the carbs off and apart, that way I know first hand the condition they are in, I would just like to exhaust all methods of troubleshooting before just incase its a simple fix! My previous post was just a reply to your post, not repeating the same problem ignoring your info. Thanks for the help tho, I appreciate it! Will report back after I remove carbs
Yes indeed, the PO took exceptional care of that bike. You may have found the very rare PO that actually has told the whole truth about the bike.
Actually its better to remove and open up the carbs,
before ordering parts, as you may very well find that you need to order other unforseen parts. i.e. a defective float, etc. Its the same mistake, the lads make when they find they have to do a top-end rebuild. They order a bunch of parts before they open up the engine, only to have to make multiple orders, once they open it up and find additional parts are needed.
You're a very typical new XS650 owner, in that they always delay as much as possible, the dreaded act of removing the carbs for disassembly. But guess what, its not really very difficult, but there are a few tricks. Trust me, you will have to remove the carbs more than once if you plan to keep the bike for a while. There is no one simple fix.
Adding a little more to what weekendrider said..................yes remove the camchain tensioner nut......................also remove the small bracket that holds the throttle cable on top of the left carb.................last but not least, remove the dip stick and put a rag in the hole to prevent anything falling in. With those 3 things done the carbs will come right out with just a little juggling, no cursing required.
I think I mentioned this in the other thread, but its super important to use a slot screw driver that fits
precisely into the slot in a pilot or main jet. I have a screwdriver that I filed and ground until it was an exact fit. If you use a sloppy fitting screwdriver, bad things can happen.
Later on once the carbs are in top notch condition, you can use a little dielectric grease on the rubber carb holders. The carbs will be much easier to push into the holders.
Another smart tip, is to replace the phillips (actually JIS) head screws that hold the float bowl on, with allen head bolts. Makes life a lot easier, and allows for removal of the float bowls, with the carbs remaining on the engine, if you ever wanted to change jet size..
