scabber
XS650 Guru
The XS pods don't work well with BS 38 carbs. UNI filters the foam type are a better choice.
lakeview.................I like your blunt way of talking! It seems that most of the novice riders, of the XS650, think that pod filters will somehow make their bike faster, give it that race bike appearance. Sorta like a sheep in a wolf's clothing.
Reality is that these bikes are slow, and not racey at all. Any bike made in the last 10 years, with 500 cc or more, will accelerate past these bikes with no effort at all.
You are a novice 650 rider and if you want to fuck up your bike with those pleated XS pods you can. I have seen nicer bikes cut up and hard tailed feel free.
... I live at a high elevation...
If you're above about 4,000-5,000 ft MSL, then you'll need to go leaner.
Carb pro's will say "You don't need less fuel, you need more air". But they're talking about jetting with the air bleed jets. Since you can't rejet the air bleeds (air jets), you've no choice but to rejet the fuel jets...
I live at 3356 ft. So your thinking 2 sizes up on pilots is too much then?
Could be. That, plus your descriptions make it sound like it's a little rich...
... this morning when I went to start it at 10 degrees celsius it started, then died right away, I had to start it then give it a few pulls of throttle before it would stay running...
Actually, that sounds about right. Cold/carburetored engines need help until they're warmed up. We do carb jettings for warmed up engines. And, use the enrichener for those startups.
i feel like this is a dumb question, but... do you guys with dual vac petcocks have a vac line from each carb holder its respective petcock? my bike has one on the left side and the right side is capped off? I feel like this is a vac issue for some reason.
You may have to jet slightly rich for the lower levels to compensate for higher elevations?
