peterg
I removed my bike's clutch assembly to get at the starter gear spring. When I put the clutch assembly back there was no tension on the clutch lever. I didn't check the lever until I had replaced the case cover and filled up the case with oil. (note to self - check lever action before reinstalling the case cover). I'm pretty sure I did not line up the hole on the pressure plate with the indentation on the clutch centre so I need to check that. I checked the worm assembly and it is working fine. There was no spare parts when I finished the re-install. Did I lose a ball bearing? Or is there some other obvious explanation?
