If you're going long or need some groceries, I see the answer right there.Can’t make up my mind
Trying to get this baby out in the line up - trying to figure out why my the left side turn signals and indicator light don’t work !What a nice collection! Super clean!
Chocolate wire has 12V when switch slid to left?Trying to get this baby out in the line up - trying to figure out why my the left side turn signals and indicator light don’t work !
I recently suffered that. The ground wire on the right rear light had gone open circuit. I had to use an ohm meter to find it. I don't remember what drove me to check it.Trying to get this baby out in the line up - trying to figure out why my the left side turn signals and indicator light don’t work !
Bad solder joint inside the switch housing is a common malady... and easily fixed.Trying to get this baby out in the line up - trying to figure out why my the left side turn signals and indicator light don’t work !
Yea, I refurbished the switch - so you are probably pointing in the right direction as everything else seem to be working ok. That was next on the list to check after switching relay didn’t make a differenceBad solder joint inside the switch housing is a common malady... and easily fixed.
Best to re-solder all 3 wires while you're in there.
Got all the wires connected correctly and all 4 turn signals have their own ground wire, so I think it’s the switch. Can’t figure out what the light checker box actually does as it somehow is in play too. Anyone know how they work or have a diagram of the inside componentsYes, both sides on the signal circuit is the same until it gets to the handlebar switch; Br/W is power from flasher into the switch that then switches onto Dark Gn (R) and Chocolate (L) out of switch. Of course they also need a ground at each light.
My bad - however looking at an actual diagram from an XS650E assembly manual I have 3 pronge and contrary to the ‘75 there is a Br /BrW & a GY(green yellow), the green yellow goes from the flasher relay to a flasher circuit unit and I can’t figure out what it does and even if it’s needed or if that causes the problem.The light checker should not be involved in the signal circuit
Go with the 75 no bags this way you have the round mirrors (stock?)Can’t make up my mind
Almost everything is stock on the ‘75 without bags, except a new front brake caliber and master cylinder - they were to gone to safe and since it’s the lifesaver figured I could live with a reproduction unit . The tanks has the original paint and it’s flawless , was in original box too- got with a load of other XS stuffGo with the 75 no bags this way you have the round mirrors (stock?)
Nice bikes
I didn't think you had the signal cancelling unit; that's where the Gn/W to flasher go. On 75-76 the 3rd wire on the flasher is ground (Bk). IIRC the cancelling unit can be disconnected and run just Br and Br/W on the flasher. So is this harness a '78?My bad - however looking at an actual diagram from an XS650E assembly manual I have 3 pronge and contrary to the ‘75 there is a Br /BrW & a GY(green yellow), the green yellow goes from the flasher relay to a flasher circuit unit and I can’t figure out what it does and even if it’s needed or if that causes the problem.
Yes it’s a ‘78 harness - actually everything to my knowledge is ‘78 standard. I tried a two pronged relay - omitting the gn/y - same result - on flashes to the right - left still dead - so I may be down to the handlebar switch as the problem.I didn't think you had the signal cancelling unit; that's where the Gn/W to flasher go. On 75-76 the 3rd wire on the flasher is ground (Bk). IIRC the cancelling unit can be disconnected and run just Br and Br/W on the flasher. So is this harness a '78?
