Eeny meeny miny moe which to ride first!
Niels B
XS650 Junkie
XS650.com Supporter
North Florida
Can’t make up my mind
Trying to get this baby out in the line up - trying to figure out why my the left side turn signals and indicator light don’t work !
Chocolate wire has 12V when switch slid to left?
I recently suffered that. The ground wire on the right rear light had gone open circuit. I had to use an ohm meter to find it. I don't remember what drove me to check it.
Bad solder joint inside the switch housing is a common malady... and easily fixed.
Best to re-solder all 3 wires while you're in there.
Yea, I refurbished the switch - so you are probably pointing in the right direction as everything else seem to be working ok. That was next on the list to check after switching relay didn’t make a difference :)
Yes, both sides on the signal circuit is the same until it gets to the handlebar switch; Br/W is power from flasher into the switch that then switches onto Dark Gn (R) and Chocolate (L) out of switch. Of course they also need a ground at each light.
Got all the wires connected correctly and all 4 turn signals have their own ground wire, so I think it’s the switch. Can’t figure out what the light checker box actually does as it somehow is in play too. Anyone know how they work or have a diagram of the inside components
Might be wrong, but I don't think the light checker has anything to do with the signals.
The light checker should not be involved in the signal circuit
I might unplug the handlebar switch and Ohm continuity between Choc. -Br/W when switch to left position from the switch harness. Should be continuity when switched each direction from Br/W to Choc. and then Dk Gn and no continuity in off.
My bad - however looking at an actual diagram from an XS650E assembly manual I have 3 pronge and contrary to the ‘75 there is a Br /BrW & a GY(green yellow), the green yellow goes from the flasher relay to a flasher circuit unit and I can’t figure out what it does and even if it’s needed or if that causes the problem.
Go with the 75 no bags this way you have the round mirrors (stock?)
Nice bikes
Almost everything is stock on the ‘75 without bags, except a new front brake caliber and master cylinder - they were to gone to safe and since it’s the lifesaver figured I could live with a reproduction unit :). The tanks has the original paint and it’s flawless , was in original box too- got with a load of other XS stuff
Hell of a find
I found the sissy bar luggage rack for my 75 by just being on Ebay at the right time haven't seen another on since
Oh and did I mention those a good looking 75's
I didn't think you had the signal cancelling unit; that's where the Gn/W to flasher go. On 75-76 the 3rd wire on the flasher is ground (Bk). IIRC the cancelling unit can be disconnected and run just Br and Br/W on the flasher. So is this harness a '78?
Yes it’s a ‘78 harness - actually everything to my knowledge is ‘78 standard. I tried a two pronged relay - omitting the gn/y - same result - on flashes to the right - left still dead - so I may be down to the handlebar switch as the problem.
I can’t stand the wire mess on these bikes - all crammed into that tiny headlight housing !
There is no schematic on the cancelling unit itself (as I'm aware) - still the effect is equal to R&L signals - it has an input from speedo W/G, input from flasher G/Y, power from Br, ground and output to handlebar sw Y/R (that incidentally is grounded by switch in on R or L).
