Pipes - simply world class build you have going there!
I'm curious on your choice of plain carbon steel round tubing for swingarm.
Cool mod with the stem nut. What size blanking nut did you use?So this week I have been slowly tinkering in the shed with the project...I have been concentrating on the headstock/yokes (trees) and fitting the correct fasteners to the engine mounting plates.I also spent a little time on the lower linkage bearings which required pressing In to the frame..I was originally going to use bronze bushes but decided on needle roller bearings.
As for the headstock,I fitted up the yokes but didn't realise till now how unsightly the stem nuts and bearing cap looked especially seeing as I'm not going to have a lot to cover it, ie headlight etc..but I managed to find a stainless pipe end cap at work which I thought could work.One hole later and a 2mm skim off each stem nut it fitted great..don't you just love it when things fall into place...having said that,it is taking time to come together despite the mock up to begin with but that's down to me spending a little more time to do things right..I don't want to get this far to simply cut corners...
Good to know.Actually, as long as stiffness (rigidity) is the main objective, then mild steel is just as good as chrome moly. It is not as strong, but has pretty much the same Young's modulus. In fact, even spring steel is not stiffer than mild steel as long as the stress is below the yield limit.
This may sound counterintuitive, but that is how it is.
I completely agree that the round tube is congruous with the rest of the chassis; looks better than the typical box section. Hey, it's different, prompting my curiosity, but that is what sets your build apart.To be honest...being on a tight budget and having mild steel already at hand helped with that decision
oh,I did toy with the idea for a rectangular section but the round stock complimented the rest of the frame.
Cheers Pipes; I'm from Wales which is also currently in the UK as it 'appensAdam C
I used a 2" dairy end cap as we call them in the UK...hygienic fittings they are also know as...
I am in Arizona.I made it from scratch mate.I found if you can't find exactly what you want then the only choice is to make it...where are you based as I'm sure you'd find a set in the UK..
Spot on Raymond. What he said.Looks like those tyres are not properly seated in the rims. The usual way to get them seated is high pressure - I've seen 100psi before a stubborn tyre POPs. Tyre fitting liquid or even Fairy liquid and water can help. The bead should end up equal around the circumference.
If they don't POP first go, sometimes I've seen the owner remove the valve to completely deflate the tyre, give it a few Whacks like @Mailman suggests, replace the valve and have another go with high pressure. Good luck.Cheers guys,I'll give them a go at the weekend.
