1. Dismiss Notice
    Dismiss Notice
Flat track project
Discussion in 'The Garage' started by Pipes, May 8, 2020.
  1. Bjorn
    Bjorn XS650 Addict
    Love the kickstarter you made! Since it a big piece of steel (similar to the OEM one) its heavy. I wonder if it could be made out of titanium...
    Raymond likes this.
  2. Bewarethemoon
    Bewarethemoon XS650 Junkie XS650.com Supporter Top Contributor
    Now you’ve really peaked my attention!
    Raymond and gggGary like this.
  3. Pipes
    Pipes XS650 Enthusiast
    53
    160
    33
    Uk
    I guess anything is possible,and i agree it is a heavy piece.
    All I know is my workmate can't wait for the day my weld snaps and leaves me stranded..he really is an arse
    Team Junk, Jim and Raymond like this.
  4. Spectacular build you are doing. Very, very nice work! Love the capping of the welds, with the intent to put clear on after. Can't wait to see it !
    Team Junk and Jim like this.
  5. Jim
    It's called TLAR engineering... that looks about right. :D
    jetmechmarty, Pipes, Raymond and 2 others like this.
  6. Pipes
    53
    160
    33
    Uk
    Now there's a phrase I'm going to start using
    Jim and jetmechmarty like this.
  7. Pipes
    53
    160
    33
    Uk
    In my break times at work this week I made some clutch spring centre retainers to replace the oe ones as the heads had seen better days.I also used some socket cap bolts instead of cross heads for piece of mind.
    Rhy650, buzzword, Mailman and 3 others like this.
  8. arcticXS
    arcticXS XS650 Guru Top Contributor
    Some MXers have alloy kickstarters, and some Yamaha models (425 and 450s ?) actually fits the XS 650, as well as the RD 250/ 350/ 400 models. The all share the same spline. This one may be an ok alternative: https://www.ebay.com/p/4008420197
    YamadudeXS650C, Jim and Bewarethemoon like this.
  9. Mailman
    Jim and arcticXS like this.
  10. TJZ662
    TJZ662 XS650 Enthusiast
    Awesome work man. Very inspiring. Is that silicon bronze over tig welds?
  11. Pipes
    53
    160
    33
    Uk
    Thanks bud..yes it is.I have always loved the look of bronze welds whether it be tig welded or brazed. I haven't acquired the true skill of gas brazing bronze quite yet
  12. TJZ662
    Same here man. I’m doing something similar with the silicon bronze, finding that pulse and a plenty big cup helps with the way it wants to kind of sag while going vertical up.
  13. Pipes
    53
    160
    33
    Uk
    That's right.I found it has characteristics not unlike solder but not quite as fluid...and this can make vertical runs look less tidy.They do clean up well though with a wire brush.
    Jim likes this.
  14. TJZ662
    I plan on using a black oxide finish where it makes sense, as the silicon bronze doesn’t accept that. Leaving it gold while the rest of the tube is blackened. Probably preaching to the choir here.
  15. Pipes
    53
    160
    33
    Uk
    No not at all...that sounds pretty cool to be honest.Id like to see it when it's done.
    TJZ662 likes this.
  16. Pipes
    53
    160
    33
    Uk
    Ok...so here I am again after some time away and I must apologise for the lack of posting and photos....I have been trying to keep my hand in on the project and I have managed to do a little since my last visit....such things include getting the motor back in the frame since the rebuild,seeing if everything still fits as it should,which it did,which is nice..I fabbed up the exhausts or rather the down tubes and link pipe,I mounted the Vape ignition ready for a new loom to be made.I also scored some brake discs at a vastly discounted price on line so I grabbed those.
    Currently I am concentrating on running the wires as neatly as poss from under the seat which will have another small alloy sheet to conceal the finished loom...I am also sourcing some carbon fibre tube for the exhaust silencer because as much as I like open pipes I want to bring the db's down a tad in case I visit a track with noise limits.All the exhaust parts are fitted with springs to make it quicker to disassemble.I have this system on another bike and it makes servicing or removing soooo much easier....Pics to follow.
    181489554_10217865214693663_5699961835084271272_n.jpg 181329920_10217865213933644_1695847539628988723_n.jpg 181759428_10217865221733839_8483176877262233931_n.jpg 181210639_10217865216773715_3319814526008098713_n.jpg 179996509_10217865217613736_6221716465172794222_n.jpg 181367356_10217865218773765_6319734506660293998_n.jpg 181130160_10217865219813791_554422369759816933_n.jpg 181796578_10217865223133874_8677497101107030109_n.jpg 180633739_10217865217973745_6742508641033700918_n.jpg 180821558_10217865223773890_1073764205037707529_n.jpg 181155746_10217865221293828_6989572074577913371_n.jpg 181569371_10217865222293853_8252045397149847944_n.jpg 179849208_10217865220653812_5440380492508970271_n.jpg
    Bjorn, arcticXS, Raymond and 5 others like this.
  17. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
  18. Bjorn
    Bjorn XS650 Addict
    Great topic mate! Is this going to be a track-only bike or you plan on taking trips with it as well?
    O and building stuff just takes time haha, before you know it, it's 2022
  19. Pipes
    53
    160
    33
    Uk
    Not enough time in the day Bjorn, at least after work and home maintenance .
    This will be a road legal bike primarily,using it for fun and ride outs with the occasional amateur dirt track visit.If I finish it Haha..
    Raymond and Bjorn like this.
  20. Vww18
    Vww18 XS650 Enthusiast
    Hi Pipes !
    Love your work, everything is so clean ! very inspiring.
    And I love the rear shock mount, It is close to what you can see on a Honda XLR 600 and it turns out to be very smooth.
    Very impressed, love it !
Share This Page
