I had some difficulty removing the sealing washer from under the Allen key at the bottom of my right hand fork. Foolishly I used heat and a small screwdriver to tap it out, unhappily creating a divot in the surface beneath. I fear this will allow a leak from the bottom of the fork.
Should I fill the divot with JB and smooth it down or glue a sandpaper disc to the bottom of a 15mm section of dowel and hand sand the entire circular surface down flush? I believe that the divot is only about 1mm deep so I don't think the Allen bolt will bottom out before it tightens sufficiently to avoid a leak
