It was tricky but even as he ran himself over with his Royal Enfield, Sgt Butterworth remembered his training and did not let go of the Maxim gun.
Definite possibility.Supercharged 2 stroke...
Simplifies bottom end design. Detroit diesel did a whole series of supercharged 2 stroke diesels, All based on a common piston dislacement. 53, 71 and 92 cubic inch piston/cylinder combos gave us 4/53, 6/71 8/71(?) 8 and 12 /92. Probably othersSupercharged 2 stroke...
And you left out a few there were 1-71's, 2-71's, 3-71's, 4-71's, the 6's came in inline and V configurations the 16V-71's. and I there were a few 24V-71's made The 92's also came in the 16V versions. Rebuilt several different models from the 4's up to a few 16V's. The 16V's were interesting as they were basically two 8V blocks bolted together front to front and cranks were joined as well. Timing gears up both ends. The 24 would have been more or less the same but using two 12V blocks and cranks.Simplifies bottom end design. Detroit diesel did a whole series of supercharged 2 stroke diesels, All based on a common piston dislacement. 53, 71 and 92 cubic inch piston/cylinder combos gave us 4/53, 6/71 8/71(?) 8 and 12 /92. Probably others
I miss the sound that they made.And you left out a few there were 1-71's, 2-71's, 3-71's, 4-71's, the 6's came in inline and V configurations the 16V-71's. and I there were a few 24V-71's made The 92's also came in the 16V versions. Rebuilt several different models from the 4's up to a few 16V's. The 16V's were interesting as they were basically two 8V blocks bolted together front to front and cranks were joined as well. Timing gears up both ends. The 24 would have been more or less the same but using two 12V blocks and cranks.
The Detroit engines were basically the Lego blocks of the diesel engine world, you could make them what ever you needed and what ever size you needed if you could imagine it they could be built to do it.
WHAT DID YOU SAY?I miss the sound that they made.
I SAID THERE'S NOTHIN' LIKE A 6-71 WITH A STRAIGHT PIPE!WHAT DID YOU SAY?
RIGHT!I SAID THERE'S NOTHIN' LIKE A 6-71 WITH A STRAIGHT PIPE!
