gggGary, nice work and documentation. Last week I had a quick try with an LED H4 bulb, the same as the one you are using with the big heat sink.
The immediate problem I struck was it activated the reserve lighting unit. It was also a bit cramped in the headlight bucket because the power connector would not push right on. I solved this by filing away some of the solder on the H4 connectors which was quite excessive.
- At approximately 1200rpm idle I observed 13.8V which is similar to your observation.
- At 1500rpm the voltage was 14.2V which is what my regulator is set for.
- On return from a 30 mile ride I was getting 14.2V at 1200rpm idle (I guess this is explained by the battery being fully topped up).
