My $Free.99 Project
wannabridin
XS650 Guru
XS650.com Supporter
Hurst, TX
got the frame painted (used KBS coatings system). once the paint is cured, reassembly can commence! At least I can get it to a roller and install the motor later on... Exciting!!!
Kevin Werner
Amatuer
XS650.com Supporter
Sheboygan, WI
it's DEF not the best looking paint job, but it's functional and way better than before!!!
Wannabridin there is a little secret I will share with you. SSSSHHHHH, don't tell any one. My Red Bike sat in my garage, on a stand, forks and swingarm, pipes etc off. I scrubbed the frame that would show with soap and water and a scotch pad. I wiped it down with alcohol and shot it with Rustoleum. The truth is very little of the frame shows and I paid attention to those areas. The exhaust hides the frame or distracts visually The pegs, sidecovers, seat, fender draw the visual. What I am saying is you will be real pleased when all the bits go back together. Now if I wanted/needed to take the engine out I would do a more thorough job, maybe a KBS or more.
cheers
wannabridin
XS650 Guru
XS650.com Supporter
Hurst, TX
Got some lighting figured out. Front turn signal mounts and possible driving light mounts are next.
