chopitdropit
1982 xs650, BS34's
From the beginning...
Bought bike with carbs that were supposed to have been rebuilt at yamaha shop, but set for a year and laquered up. Cleaned them and checked everything out (twice), reassembled and bike fired up but with high idle.
Discovered air leak at right carb boot where it bolts to cylinder. After no success stopping (there was no rubber coating left where they meet the cylinder and gaskets and sealer didn't help), I ordered new boots and diaphrams from JBM (also had a questionable diaphram).
After installing new parts, I discovered that I now had an air leak at the left boot BUT other than high idle and a little miss at mid throttle (which seemed to improve if I ran at half choke) the bike ran like a bat outta hell...so tired of messing with it, I hit the open road for a day of riding with no probs other than the irratating high idle (which I am still trying to seal...).
OK..now for the new problem. I went out to work on it today and on top of the high idle, it is backfiring a bit and running rough at all ranges and the left cylinder is putting out a lot more forceful exhaust than the right cylinder.
This has to be something else besides the high idle from the air leak, because I rode all day yesterday with no other problems????
Any ideas?
I might mention I am running pods, straight exhaust (homemade) and have no idea what jets, but this doesn't seam to be an issue when I'm riding.
Also I noticed that the Orings on my air mix screws are not really O's but kinda flat on one side...but they are both the same..is this normal? (they are out 2 1/4 BTW which is where they were when I got the bike). I have nothing to gauge by...this is all new to me...just learning as I go.
Oh...valves are adjusted. Also have freshly red koted tank cured properly, clean filter, new petcock (non vacuum and ordered the boots with no vacuum fittings, and am running clear gas line so I can see my gas flow)
Stumped...
Just noticed I posted a pic from when the carbs were off...haha
Additional info...just pulled the plugs, right side good, left side black sooty although that is the side sucking extra air? But from what I have read on the forum, many have bikes that run good and one plug is black sooty.
Any ideas?
Stumped...
