Two posts ago, 2M gave me some tests to perform that would be quick and easy to try before changing points and messing with advance assembly.
Left side
- Turn in mix screw fully, stalls.
- Return mix screw, block Pilot air port, stalls
- Left carb pilot circuit looks good
Right side
- Turn in mix screw fully, should stall but runs really well, no miss, stumble or climbing idle….huh
- Return mix screw, block pilot air port, slightly rougher running, idle increases
- Right carb pilot circuit looks like it’s still plugged somewhere
So I figured 2M had me onto something here.
I must have missed something and wondered if pilot circuit must be blocked somewhere and the carb was compensating somehow and running off another circuit. So I tore them down again, which is no big deal, I think I’ve gone to the dark side as I actually enjoy working on carbs. Someday I hope to be able to get them to work again too.
Once again cleaned every orifice and passageway. I enjoy figuring out how they all connect and operate.
Found no blockages, but maybe something so fine carb cleaner or compressed air blew it out and I didn’t see it. But I figured it would have had to have been a full blockage to shut down pilot circuit.
Also installed new 135 Mains and 27.5 Pilots while I had them apart.
After remount:
Left side
- Return mix screw, block Pilot air port, stalls.
- Left carb pilot circuit looks good.
Right side
- Turn in mix screw fully, runs great, smooth, no miss, no hunting idle, will idle and purr right down to 700-800 rpm
- Return mix screw, runs rough again, block Pilot air port, idle increases
- Still looks like blocked pilot jet circuit but I can't see how.
So, I know that every carb port and passageway are clear.
How can pilot be affected this way? Fuel and air are coming from somewhere with the mix screw fully closed. Could the fuel be being drawn in from the left carb fed from fuel line link/crossover tube and the air from a leak?
At first the right side was backfiring a bit, had never had any real backfiring before. Then it got worse. Sprayed carb cleaner around exhaust pipe manifolds on both sides, no effect.
Then sprayed carb cleaner on the carb mounts, clamps are done up so both halves are tight together as per 5twins recommendation, no butterfly binding:
- Left side leaked on carb side of mount, idle increased slightly with CC.
- Right side leaks a lot worse on both carb and engine side of manifold, idle increase more dramatically with CC.
I thought I had tested all this, but that was awhile back.
Right manifold is badly cracked in several places the full depth of the carb mount area and rubber is very hard.
Left manifold has a couple small cracks, not very deep and is much softer. That makes sense as I remember replacing it years ago chasing a leak.
I had a couple of 78/79 manifolds that I got for $25 with one of the carb sets I bought. Hoping they’ll be good, and will be nice to have those barbs for syncing too.
They look OK. Didn’t notice any major cracking and they were softer.
Still waiting for the gaskets I ordered for them, so I picked up a sheet of Felpro gasket maker material from NAPA and made some gaskets. Installed with Hylomar Blue sealer on both sides, just to be sure.
As always, one easy kick, Idled smooth, turned idle down to about 700-800 rpm. (Don't know how accurate my tach is and haven't puzzled through how to use the tach feature on my 'Little yellow meter’ yet.) Then raised to 1200, and it ran just like it should, shut it off after a few minutes.
Was thinking I’d take it for a test spin, so put the air boxes back on and fired it up again.
Now that it had warmed up, all the rough running symptoms are back. Backfiring worse now, so where’s the air leak now?
The new right manifold is leaking on the carb side so badly I can hear chirping now. Didn’t need Bob’s hose-oscope, but used it anyways just because it’s cool,and it's definitely leaking around the carb/manifold joint.
Sprayed left and right sides with CC, gaskets are good, but right carb side of manifold is leaking, maybe slight effect on left. Clamps are tight together.
However, the pilot circuit on the right side is now operating properly and will stall with both tests. I guess that proves that this manifold is sealing somewhat better than the last one.
Since I have it I'm going to try swapping my old left side manifold for my new right and see if there is any improvement.
So looks like I may shopping for new carb manifolds. I know I don’t want to use Mikes/XS650Direct.
Any suggestions for Manifolds? Or for anything else I can try?
Will get to new points, but don’t see the point in that yet.
