Hi all!
Here I am again, at sea, and with time left over for an hour or two at the lathe!
I would like to remove the speedo drive on my 1977 XS, and would need some measurements from the axle and the tacho drive unit, in order to make a spacer ("speedo delete")
I have a hub at hand, and I know axle diameter is 17 mm, but that is the only measurements i have available.
- What is the inner length of the speedo drive? (from wheel bearing to shoulder on axle, when assembled)
-What is the larger diameter of the axle?
Appreciate any info
Appreciate any info
