Seat lock
Miker
Rockingham , Western Australia
I have managed to find a New Old Stock seat lock. It came with 2 keys but seems to be missing a spring and some sort of locking lever inside the lock . Does anyone have pictures of what I need and possibly dimensions. Spring would be easy to get but not sure about making the other piece. Need a closeup pic of the lever if possible.
It appears you're missing another little piece as well. There's a small tin cover that presses in the top, over that latch part and spring you're also missing .....
It's just a light friction fit into the lock body so it's easy to pry out and press back in. What really holds it in place is when you screw the lock to the frame .....
Grid is 5mm X 5mm.
Latch is 36 X 12 X 4.5mm. Measurements do not need to be precise, there is a lot of slack in how it functions.
Spring is 5.5 X 15mm.
The little cover in 5twins pictures is not critical. It just keeps everything in place until you mount the lock on the frame. It will work without that cover -- when mounted, the frame will do the same thing the cover does, keep everything in place.
