Swapped my 38s for a set of VM34. Everything was running before, however I was running VERY rich with the 38s. 34s are setup as such:
159p6 needle jet
6f9 needle 3rd clip
25 pilot
180 main
.905"/23mm float level
5/32" slide level
I cannot get the bike to start now. I haven't checked the ignition side yet as I didn't mess with that, but that will be coming if it turns out not to be the carbs. Ive tried choke, no choke, turned the idle a turn in, and messed with the mixture from 3/4-1 3/4 turns. After trying to kick it a handful of times, there is a pool of fuel in the intake boots. Any idea why it isn't starting? The only thing that I can figure would cause this is the float level, unless something is wrong on the ignition side.
159p6 needle jet
6f9 needle 3rd clip
25 pilot
180 main
5/32" slide level
