TurboFarviknugn
Ok been riding my bike for several months on a daily basis over 2,500 miles since finishing my build. Have had several issues related to VIBRATION and it being a hard tail on shitty San Antonio roads. Any way on my way home from work today my bike starts running like crap almost like running out of gas. I pulled off the road checked yep plenty of gas, killed the headlight as I didnt want to kill the battery during troubleshooting. Start it up allseems ok start riding home realized headlight is off so I turn it back on viola runs like crap and dies at the next light. Finally nursed it home started checking wiring (which is a complete NEW from scratsh harness ) found a slightly scorched connector.
upon checking things out when the headlight is on it is VERY DIM, so I checked voltage, the battery with everything off is sitting at 9 volts, and upon firing it up and checking again it is at 6 volts. That explains the dim headlight and overall crappy running with light off and worse when on.
The bike has a NEW battery (4 months old ) a PMA charging system scavanged from a banshee ect... I know PMA set ups require ATLEAST 12 volts to run properly, question is what should I be looking for when I pull off the left cover ? Any ideas as to what would have caused this ? I have checked everything else and find nothing out of the ordinary.
Voltages were checked off the battery terminals.
ANY help is GREATLY APPRICIATED !!! Electrical is my weak spot.
THANKS !!!!
THANKS !!!!
