I have found that it’s a PITA to remove the front wheel because I have a twin disc arrangement. The UK 75 B models came with twin discs but I believe they were a small diameter disc, mine has two full size discs and it’s impossible to remove the wheel through the gap between the callipers. Which means removing one calliper which in turn means removing the mudguard and rotating one fork slider to enable the calliper bolt to come free of the slider.
Did a bit of thinking and came up with an alternative calliper mounting for the RH calliper top bolt. Now I should be able to take out both studs, slide the calliper out of the way and remove the wheel.
