Yes. I’m building up the forks from my parts stash. The seals will come out first.If you're going to powder coat the fork lowers, remove the seals first. I worked on some that had been powder coated with the seals still installed. I had to replace the seals and they were a bitch to get out after having been baked in there during the powder coating process, lol.
Three half millimeter shims won't be tight. It should fill the gap, so I won't have the bushing rotating on the pin as I was on the other bike.Honestly, I don't think these need to be shimmed tight, just enough to take up most of the space so pinching the frame in isn't doing it.
I'm not equipped to do that. Having the brown truck drop shims at my door is far easier to do.Maybe stainless steel sheet metal is worth considering and doing those shims yourself.Or one only 1.5 mm
With the option to grind to the exact thickness you want.
Any sheet metal shop here has a piece of scrap one could get.
Stainless is a bit worse to work with but doable.
I've had good luck with a good set of long handle safety wire pliers.... as long as the jaws still have good knurling. It's amazing how much leverage and grip you get with 'em.Perhaps I should just leave that screw alone and....
Perhaps I should just leave that screw alone and break the cam chain. It’s hard to work between all those studs that I’d rather leave alone.
Issue #1 is the screw head is boogered. I’ve tried your suggestions other than the heat. I’ll give that a go next time I pick up the tools.I had problems with one or two of those
A friend had a small gas torch heating and some light oil there most likely
And I used a 1/4 inch ratchet
Correct bit pushing down as Hard I could with the left hand and untighten with the right hand
Both came out.
Can try a little in the tightening direction and if possible use a drift on the top end move it inwards
It worked! I didn't have Kroil, so I substituted Jerk Off. Don't Google it!Heat then Kroil. Repeat.
Now you tell me!Yes, I was going to ask what the whole point was for taking that tensioner off in the first place, lol. Breaking the chain is no big deal. These bikes came from the factory with a split chain joined by a master link. I've always split the chain (and replaced it with a new one).
I didn’t need this frame. It went back to Georgia. The frame I started with now has a Mississippi title and current registration. All I lack is assembling a motorcycle.View attachment 193252
It’s a disk brake frame. It fits in the trunk of a Ford Focus. Who’d a thought!
