1980G SII.....same as the 78/79 special metal side-covers .......the swing-arm has the removable blocks on the end, the standards and 78/79 Specials,had so the rear wheel could be taken off without removing the mufflers.
The one in the trunk is a ‘79 Special. It’s going to be a Special II, sort of.1980G SII.....same as the 78/79 special metal side-covers .......the swing-arm has the removable blocks on the end, the standards and 78/79 Specials,had so the rear wheel could be taken off without removing the mufflers.
That might be a good idea. It will be a couple weeks before I can get back to it.I want to see those BS34's fit there !
Deep grooves in outer clutch basket 6 o clock ?? ??
Jim's rule of thumb for known perishable bits.....The cam chain is tight. So, I don’t think I’ll replace it.
