glennpd
4 bikes, 4 dogs, 1 wife
Ok, here is the breakdown.
What else can be causing unregulated voltage?
Thanks
Glenn
- Stock 80G
- New Rotor 5ohm slip ring resistance (Used)
- New wiring loom (MikesXS)
- No short on green wire
- Continuity on green
- disconnected brush
- connector before regulator
- Near battery voltage (-.3v) on brown wire with headlight on
- Open between green and brown at the connector
- Replaced the brush holder
- Brushes not grounded
- Replaced Rec/Reg (Used)
- Fully tested Rectifier (Following Ken Maxwell procedure)
- Fully tested Regulator (Following Ken Maxwell procedure)
- Not sure about reserve lighting device but who cares?
- Start motor 16v at idle ???
Thanks
Glenn
