inxs
xx
SWAPPING FRONT ENDS - Example - ZX10 forks and wheels to an XS650 hard tail frame.
http://www.bikers1.com/mhst.htm
- you can also swap stems, press out of your XS triples, repress into suitable yokes...eg USD...weld the bottoms for safety...generally press out from the top side
- i cant remember where i got these lists from, if any one knows please post it
Edit by gggGary, All balls now has a fork swap bearings needed tool, VERY useful!
http://www.allballsracing.com/index.php/forkconversion end edit.
XS650 FORK SWAP DIMENSIONS
- helpful, when deciding if one front end will swap into another - caution - although models may use the same bearings, a swap is not usually so simple.
...overall width is a factor
...steering stem length is another - eg, CB750 and CB450 use the same bearing but the CB450 stem is about 1" shorter.
...steering stock at the bearings are different - so long as the outside dimension is the same use bearings with a suitable inside dimension - or machine the stock...
...steering stops not positioned correctly - grind off , create a new one
...handlebar geometry may not be comfortable or even possible
Upper: 25 x 48 x 15.2
Lower: 30 x 48 x 15
Yamaha FZR400R
Yamaha SRX400
Yamaha SX500B/C/D/E (75-78), TX500/A (73-74)
Yamaha XS550RK/RJ (82-83), XZ550RK/RJ (82-83)
Yamaha FZ600 (86-88)
Yamaha SRX600S/SC (86), SRX600T
Yamaha TX650/A (73-74)
Yamaha XJ650G/H//J/K (80-83), XJ650LH (81), XJ650LJ/LK/RJ (82-83)
Yamaha XS6501/1B/XS2 (70-72), XS650B-H/2F (75-81), XS650SE-SH (78-81), XS650SJ/SK (82-83)
Yamaha TX750 (73-74)
Yamaha XJ750J/K/MK/RH/RJ/RK (81-83)
Yamaha XV750H/J/K/MK (81-83), XV750SE (82)
Yamaha XV920J/K/MK (82-83), XV920RH/RJ (81-83)
Yamaha XV1000K/L Virago (83-84)
FORK TUBE SWAP 36mm
This doesnt do much good for people with usd forks.
Axle diameter and tube length, not listed
36 Honda XR-200R (84-02)
36 Kawasaki KX-80 T2-T4 (92-94)
36 Kawasaki KX-85 A1-A4 (01-04)
36 Kawasaki KX-100B5-B7 (95-97),
36 Kawasaki KX-125 A4-A5 (78-79)
36 Kawasaki EL-250B2/B3 (88-89)
36 Kawasaki EX-250F2-F4, F6-F18 "Ninja 250R" (88-90, 92-04)
36 Kawasaki KL-250A3-A5 (80-82)
36 Kawasaki KL-250D2-D21 "KLR250" (85-04)
36 Kawasaki KLX-250A1/A2 (79-80)
36 Kawasaki KX-250 A/A1/A2 (74-76)
36 Kawasaki KX-250 A3 (77)
36 Kawasaki KX-250 A4 (78)
36 Kawasaki KXT-250A1/A2 (84-85)
36 Kawasaki KX-400 A1/A2 (75-76)
36 Kawasaki EN-450A1-A6 "454 Ltd" (85-90)
36 Kawasaki H1-B/D/E/F (72-75)
36 Kawasaki EN-500A1-A7 "Vulcan 500" (90-96)
36 Kawasaki KH-500A8 (76)
36 Kawasaki KZ-550A1-A2 (80-81)
36 Kawasaki KZ-550A3-A4 (82-83)
36 Kawasaki KZ-550C2-C4 "Ltd" (81-83)
36 Kawasaki KZ-550F1/F2 "Spectre/Ltd" (83-84)
36 Kawasaki KZ-650B1-B3 (77-79)
36 Kawasaki KZ-650D1-D2 "SR" (78-79)
36 Kawasaki KZ-650F1 (80)
36 Kawasaki KZ-650H1-H3 "CSR" (81-83)
36 Kawasaki KZ-700A1 (84)
36 Kawasaki KZ-750B1-B4 (76-79)
36 Kawasaki KZ-750F1 "Ltd" (83)
36 Kawasaki KZ-750E1 (80)
36 Kawasaki KZ-750E2-E3 (81-82)
36 Kawasaki KZ-750K1/K2 "Ltd" (83-84)
36 Kawasaki KZ-750M1 "CSR" (82)
36 Kawasaki KZ-750N1/N2 "Spectre" (82-83)
36 Kawasaki Z1/A/B 900 (73-75)
36 Kawasaki KZ-1000A1-A4 (77-80)
36 Kawasaki KZ-1000D1/ D3 "Z1-R" (78, 80)
36 Suzuki RM-100 K3 (03)
36 Suzuki RM-125 B/C (77-78)
36 Suzuki PE-175 C/N/T/X (78-81)
36 Suzuki RS-175 T/X/Z (80-82)
36 Suzuki DR-250 Z/D/E/F (82-85)
36 Suzuki PE-250 B/C (77-78)
36 Suzuki PE-250 N/T/X (79-81)
36 Suzuki RS-250 T/X (80-81)
36 Suzuki TS-250 T/X (80-81)
36 Suzuki DR-370 C (78)
36 Suzuki DR-370 N (79)
36 Suzuki SP-370 C (78)
36 Suzuki DR-400 T (80)
36 Suzuki PE-400 T/X (80-81)
36 Suzuki SP-400 T (80)
36 Suzuki DR-500 X/Z/D (81-83)
36 Suzuki SP-500 X/Z/D (81-83)
36 Yamaha YZ-80 E1/F1/G1/H1/J1/K1/L1/M1/N1 (93-01)
36 Yamaha YZ-85P-S (02-04)
36 Yamaha YZ-100 J/K (82-83)
36 Yamaha YZ-125 D/E/F/G (77-80)
36 Yamaha IT-175 D/E/F (77-79)
36 Yamaha IT-175 G/H (80-81)
36 Yamaha TT-225 S/T (86-87)
36 Yamaha TTR-225 L/LC, N/NC/P/PC/R/RC/S/SC (99, 01-04)
36 Yamaha XT-225 D/DC-S/SC (92-04)
36 Yamaha DT-250 F (79)
36 Yamaha IT-250 D/E/F (77-79)
36 Yamaha IT-250 G (80)
36 Yamaha XT-250 L/LC (84)
36 Yamaha TT-250 G/H/J (80-82)
36 Yamaha TZ-250 G/H/J (80-82)
36 Yamaha TY-350 N/S (85-86)
36 Yamaha XT-350 L/LC/N/NC/S/SC/T/TC/U/UC/W/WC/A/AC/B/BC (84-91)
36 Yamaha XT-350 D/DC/E/EC/F/FC/G/GC/H/HC/J/JC/K/KC (92-98)
36 Yamaha XT-350 L/LC/M/MC (99-00)
36 Yamaha IT-400 C/D/E/F (76-79)
36 Yamaha IT-425 G (80)
36 Yamaha TT-500 C/D/E (76-78)
36 Yamaha TT-500 F/G/H (79-81)
36 Yamaha XT-500 C/D/E/F/G/H (76-81)
36 Yamaha XV-500K "Virago" (83)
36 Yamaha XV-535 T/TC/U "Virago" (87-88)
36 Yamaha XV-535 E/EC/F/FC/SF/SFC/G/GC/SG/SGC "Virago" (93-95)
36 Yamaha XV-535 H/HC/SH/SHC/J/JC/SJ/SJC "Virago" (96-97)
36 Yamaha XV-535 K/KC/L/LC "Virago" (98-99)
36 Yamaha XJ-550 H/J/K "Maxim" (81-83)
36 Yamaha FJ-600 L/LC/N/NC (84-85)
36 Yamaha FZ-600 S/SC/T/TC/U/UC (86-88)
36 Yamaha SRX-600 S/SC (86)
36 Yamaha YX-600 S/SC/T/TC/U/UC/W/WC/A/AC "Radian" (86-90)
36 Yamaha XJ-650 G/H "Maxim" (80-81)
36 Yamaha XJ-650 J/K "Maxim" (82-83)
36 Yamaha XJ-650 RJ "Seca" (82)
36 Yamaha XJ-750J/K "Maxim" (82-83)
36 Yamaha XJ-750RH/RJ/RK "Seca" (81-83)
36 Yamaha XS-750 2D (77)
36 Yamaha XS-750 E/F (78-79)
36 Yamaha XV-750 H "Virago" (81)
36 Yamaha XV-750 J/K "Virago" (82-83)
36 Yamaha XV-750 MK "Virago" (83),
36 Yamaha XS-850 G/H (80-81)
36 Yamaha XS-850 LG/LH/SG/SH (80-81)
36 Yamaha XV-920 J "Virago" (82)
36 Yamaha XV-920 K "Virago" (83)
36 Yamaha XV-920 MK "Midnight Virago" (83)
Upper: 30 x 48 x 14
Lower: 30 x 52 x 17
Kawasaki EL250B2/B3 (88-89), EL250E1/E2 (91-92), EL250D4/D5 (93-94)
Kawasaki EX250E/E2/F2-F4 (86-90), EX250 F6/F7/F8/F9,F10/ F11 Ninja250R (92-97), EX250 H1-H5 (90-94)
Kawasaki ZX400H1/H2, ZXR400R
Kawasaki EX500A1-A7 (87-93), EX500D1-D4 (94-97)
Kawasaki KZ550A1-A4/C1-C4 (80-83), KZ550D1 (81)
Kawasaki KZ650B1-B3/C1-C4/D1/D2/E1/F1/H/ H1-H3
Kawasaki KZ750B1-B4 (76-79), KZ750E1-E3 (80-82)
Kawasaki KZ750G1 (80), KZ750H1-H4(80-83), KZ750K1/K2 (83-84), KZ750M1 (82), KZ750T
Kawasaki KZ900A4/B1 (76)
Kawasaki Z1 900A/B (73-75)
Kawasaki Z1R Series (78-80)
Kawasaki KZ1000A1-A4/B1-B4 (77-80), KZ1000D1 (78), KZ1000D3/G1 (80)
Upper: 22.5 x 41 x 12.5
Lower: 24 x 41 x 12.5
Honda MB-5-50 (82)
Honda MR-50/K1 (74-75)
Honda MT50Z, MTX50
Honda NSF50F (90)
Honda Z50A/K3-K5/RH/RJ, Z50A (71-76)
Honda Z50R (79-87), Z50RD (86)
Honda CR60R (83)
Honda ATC70/K1 (73-74), ATC70 (78-85)
Honda CL70/K1-K3 (69-73)
Honda CT70/K1-K4 (69-76), CT70H/HK1 (70-73), CT70 (76-82)
Honda SL70/K1 (71-73)
Honda XL70 (74-76)
Honda XL75 (77-79)
Honda XR75 (73-78)
Honda MB80, MBX80RFD/RSD
Honda MTX80/C
Honda XL80S (80-85)
Honda XR80 (79-84), XR80RF-R (86-98)
Honda ATC90 (75-85)
Honda CS90
Honda CT90 (68-79)
Honda SL90 (69)
Honda ST90K1-K4
Honda CB/CL100/K1-K3 (76-78)
Honda SL100/K1-K3 (70-73)
Honda XL100/K1 (74-75), XL100/S (76-85)
Honda XR100RP-R (85-98)
Honda ATC110 (79-85)
Honda CT110 (80-86)
Honda XL110/S (76-85)
Honda ATC125M (84-87)
Honda CB125/S (76-85), CB125T/J (78-81), CB125TT (90)
Honda CG125
Honda CM125T/J (82-85)
Honda CR125M/M1 (74-78)
Honda CT125 (77), CT125H/J/K (87-89)
Honda MBX125
Honda MT125 (74-76), MT125R/RII (77-78)
Honda SL125/K1/K2
Honda TL125/K1/K2/S (73-76)
Honda XL125K-3 (78-79), XL125S (79-85)
Honda MR175K (75-77)
Honda ATC185/S (80-83)
Honda CM185C (78), CM185T (78-79)
Honda XL185S (79-83), XL185SH/SJ/SK
Honda XR185 (79)
Honda ATC200 (79-83), ATC200E Big Red (82-84), ATC200S (84-85)
Honda CM200T (80-82)
Honda XR200 (80-83)
Honda CB250N (Late Models)
Honda CBX250F (85)
Honda CM250C (82-86), CM250T (80-82), CMX250C/CD (85-87)
Upper:30 x 55 x 17
Lower: 30 x 55 x 17
Suzuki GSXR600 (97-00)
Suzuki GSXR750 (96-01)
Suzuki TL1000R (98-00)
Suzuki TL1000S (97-01)
Suzuki GSXR1300R (99-00)
Yamaha YZFR6 (99-01)
Yamaha YZF-R1 (99-00)
Upper: 25 x 47 x 15
Lower: 30 x 55 x 17
Honda CB750KZ/FZ
Honda CB900FZ
Honda CBX/Z
Honda GL1000 (77-79), GL1000K3/Z
Kawasaki KX125 (82-91)
Kawasaki KDX200 (83-98)
Kawasaki KX250A5-A7(79-81), KX250B1/C1/C2/D1/D2/E1/F1/G1/H1/H2 (82-91)
Kawasaki KXT250A1/A2/B1/B2 (84-87)
Kawasaki KDX420B1 (81)
Kawasaki KX420A1/A2 (80-81)
Kawasaki KDX450A1 (82)
Kawasaki EX500B1-B4 (88-91)
Kawasaki KX500A1/A2 (83-86) B1/B2 (85-86), C1/D1 (87-88), E1-E3/E4/E5 (89-93)
Kawasaki ZG1200B1-B12 Voyager (87-98)
Suzuki DR125SER/SES/SET/SEV (94-97)
Suzuki RM125J
Suzuki PE/RS175T-E (80-84)
Suzuki DR200SET/SEV/ SEW (96-98)
Suzuki DR250 (90-91), DR250S L/M/N/P/R /SES (90-95)
Suzuki GN250Z/D/F (82-85), GN250Z-ER (81-95)
Suzuki GSX250F M/N/P/R (91-94)
Suzuki PE250T/X (80-81)
Suzuki RG250G/FG (85)
Suzuki RGV250K (88-89), RGV250M/N/P/R (91-94)
Suzuki RM250J (88)
Suzuki RS250T/X (80-81)
Suzuki DR350 (90-98)
Suzuki DR350S L-HR (90-94)
Suzuki DR350SL/SM/SN/ SP/SER/SES/SET/SEV/SEW (90-98)
Suzuki DR400T (80) DR400ST
Suzuki GN400 (80), GN400T/TX/TZ (80-82)
Suzuki GSF400M (91-93), GS400 Bandit (91-93)
Suzuki GSX400EE/SE/EF/SF (85), GSX400ET/ST/EX/ SX/X
Suzuki GSXR400F
Suzuki PE400T/X (80-81)
Suzuki GS450E T/X/Z/D (80-83)
Suzuki GS450G Z/D/F(82-85), GS450L (80-88)
Suzuki GS450TX/TXZ/TXD/TZ (81-83)
Suzuki DR500X/Z/D (81-83)
Suzuki DR/PE500T/X (80-81)
Suzuki GS500E/EK/EV (89-00), GS500L (80-83)
Suzuki RG500G
Suzuki SP500X/Z (81-82)
Suzuki GS550E (83), GS550EF (85), GS550ESE/ESF (84-86), GS550ESG (86)
Suzuki GS550ET (80), GS550L (80-83), GS550LF/LG (85-86), GS550MZ (82), GS550TX (81)
Suzuki GSF600 (1996-00)
Suzuki GSX600FJ-FW (88-01)
Suzuki GSXR600WN/WP (92-93)
Suzuki RF600R (P/R) (93-94), RF600RR/RS /RT (94-96)
Suzuki DR650RE R/UR (94)
Suzuki DR650SN/SP (92-93)
Suzuki GS650D/XD (83), GS650EX/EZ (81-82), GS650GL (81-83), GS650 GX/GZ/ GD (81-83), GS650 MD (83)
Suzuki LS650F/P/G/J/K, LS650PS/PT/PV/PW Savage (95-01)
Suzuki NX85D (83)
Suzuki SV650 (99-00)
Suzuki GS700EF/ESF (85)
Suzuki GV700GLF (85)
Suzuki VS700 (86-87)
Suzuki DR750S/SU/J/K
Suzuki GS750ED/ESD (83), GS750ET/EX/EZ (80-82),GS750LT/LX (80-81), GS750SD (83), GS750TZ/TD (82-83)
Suzuki GSX750EF/F (85), GSX750ES D/E (83-84), GSX750F(89-92), GSX750FK-FT (89-96), GSX750S S/D (83)
Suzuki GSXR750 (86-95), GSXR750W N/P/R
Suzuki 750T/X (81-82)
Suzuki VS750G (88-91)
Suzuki VS800GLN-GLT Intruder (92-01)
Suzuki VX800L/M/N/P (90-94)
Suzuki VZ800V/W Marauder (97-01)
Suzuki GS850G/GL (79-83)
Suzuki RF900RR/RS/RT/ RV (94-97)
Suzuki GS1000C/EC/HC/N (78-79), GS1000ET (80), GS1000G/GL (80-81), GS1000L N (79)
Suzuki GS1000LN/SN/ST (79-80), GS1000SZ (82), GS1000T/HT/ ET (80)
Suzuki GS1100E (80-83), GS1100G/GL(82-83), GS1100GK (82-84), GS1100LT (80), GS1100SD (83)
Suzuki GSX1100E/ES/EF, GSX1100E T/X (80-81)
Suzuki GSX1100EE/ESF/EFF/EF/ESF/EFF (84), GSX1100F (90-93)
Suzuki GSX1100FJ-FP (88-93), GSX1100G M/N/P/R (91-94)
Suzuki GSX1100LT/ST (80), GSX1100 LN/SN (79), GSX1100S Z/D (82-83)
Suzuki GSXR1100 (90-93), GSXR1100F (88-92), GSXR1100G-M (86-91), GSXR1100WP/WR/ WS/WT/WV (93-98)
Suzuki GS1150EF/EG (85-86), GS1150ES3/ESE/ ESF (83-85)
Suzuki GSX1150E (83-86)
Suzuki GSF1200SV/SAV (97-01)
Suzuki GV1200GLF/GLG (85-86)
Suzuki GV1400G (86-89)
Suzuki VS1400 (87-01)
Suzuki VS1400GL H/R (87-01)
Suzuki VL1500 (98-01)
Yamaha BW80S/T/U/A (86-90)
Yamaha YZ100J/K (82-83)
Yamaha YZ125D-S (77-86)
Yamaha IT175D-K (77-83)
Yamaha IT200L/N/S (84-86)
Yamaha IT250D/E/F/G/H/J/K (77-83)
Yamaha TZ250F/G/H/J (79-82)
Yamaha TZR250R
Yamaha XT250L/LC (84)
Yamaha YZ250D-T (77-87)
Yamaha TT350S/T (86-87)
Yamaha XT350N/NC-K/KC (85-98)
Yamaha IT400D/E/F (77-79),
Yamaha FZR400 (88-90)
Yamaha YZ400D/E/F (77-79)
Yamaha IT425G (80)
Yamaha IT465H/J (81-82), YZ465G/H (80-81)
Yamaha IT490K/L (83-84), YZ490J-A (82-90)
Yamaha RZ500N (85)
Yamaha XT550J/K (82-83)
Yamaha FZR600 (89-99)
Yamaha TT600L/N/S/T/U (83-88)
Yamaha XT600L/LC-G/GC (84-95)
Yamaha YZF600 (95-00)
Yamaha XV650 (98-01)
Yamaha FZ700T/TC (87), FZX700S/T/TC (86-87)
Yamaha XJ700N/NC/S/SC/XN/XS/XSC (85-86)
Yamaha XV700 Virago (84-87)
Yamaha FZ750N/S/SC (85-86), FZ750U/UC (88)
Yamaha FZR750RT/RU (87-88), FZR750R (90), FZX750 (87-89)
Yamaha XS750 ALL (77-79)
Yamaha XTZ750 (93)
Yamaha XV750 Virago (88-97)
Yamaha YZF750 (94-98)
Yamaha XS850 ALL (80-81)
Yamaha TDM850 (92-93)
Yamaha XJ900RK (83), XJ900FN (85)
Yamaha FZR1000 (87-91), FZR1000 EXUP (83-95)
Yamaha XV1000 Virago (84-85)
Yamaha FJ1100 (84-85)
Yamaha XJ1100J (82)
Yamaha XS1100ALL (78-81)
Yamaha XV1100 Virago (86-97)
Yamaha FJ1200 (86-91)
Yamaha VMX1200 V-Max (85-97)
Yamaha XVZ1200 Venture (83-85)
Yamaha XVZ1300 Venture (86-93)
Yamaha XVZ13 Royal Star
Upper: 25 x 48 x 16
Lower: 27 x 48 x 14
Suzuki RM125A/B/C (75-78)
Suzuki PE175C/N (78-79)
Suzuki GS250FW (85)
Suzuki GSX250T/ET (80)
Suzuki GT250A/B (76-77)
Suzuki PE250C/N (78-79)
Suzuki RM250A/B/C/C2
Suzuki TM250K/L/M (73-75)
Suzuki TS250 (70-79)
Suzuki GS300LF/LZ/LD (82-85)
Suzuki RM370A/B/C (76-77)
Suzuki SP370 (78-79)
Suzuki GT380K-B (73-77)
Suzuki GS400B/C/EC (77-78)
Suzuki RM400C (78)
Suzuki SP400T (80)
Suzuki TM/TS400 (73-77)
Suzuki GS425N/EN (79)
Suzuki GT500A/B (76-77)
Suzuki RE-Rotary (75-76)
Suzuki GS550B/C/EC (77-79)
Suzuki GT550J-B (72-75)
Suzuki GS750B/C/EC/N (77-79), GS750D C/N (78-79), GS750EN/ LN/LT (79-80)
Suzuki GT750 (72-77)
Upper: 25 x 48 x 13
Lower: 30 x 48 x 13
Suzuki RM100N/T/X (79-81)
Suzuki RM125N/T (79-80)
Suzuki RM250N/T (79-80)
Suzuki RM400N/T (79-80)
Yamaha L5T/L5TA-100 (69-70)
Yamaha RD125B/C (75-76)
Yamaha RD125LC
Yamaha TA125 (Roadrace)
Yamaha TD2/TD2B125 (70-71)
Yamaha TR2/TR2B125 (70-71)
Yamaha TZ125G (Roadrace) (80)
Yamaha YB125E/F
Yamaha RD200A/B/C (74-76)
Yamaha YTM200N/ERN (84)
Yamaha YTM225DRN/DRS (85-86)
Yamaha YTM225DXL/DXN (84-85)
Yamaha FZR250
Yamaha RD250 /LC (73-82)
Yamaha RD250YPVS (83-84)
Yamaha SR250G/H/J/TH (80-82)
Yamaha SRX250N (85), SRX250T/TC (87)
Yamaha TD3/TR3-250 (Roadrace) (72)
Yamaha TZ250 (73), TZ250C/D/E (76-78)
Yamaha TZR250 (87-91)
Yamaha XS250
Yamaha XV250U-W (88-89), XV250A/AC (90), XV250G/GC/H/HC/J/JC (95-99)
Yamaha R5/B/C (70-72),RD350 (73-79), RD350LC (80-82)
Yamaha RD350YPVS (83-84), RZ350L/N/NC (84-85)
Yamaha TZ350C/D/E (74-78)
Yamaha XS360C/D/2D (76-77)
Yamaha RD400A/B/C/D (76-79)
Yamaha XJ400 (80-85)
Yamaha XS400E/F/2E/2F (77-79), XS400G/H/J/K (80-83), XS400RJ/RK (82-83), XS400SG/SH (80-82)
Yamaha XV500 (83) XV535 (87-99)
Yamaha XV535 (91-94), XV535H/N (89-90), XV535SE (88), XV535T/TC/U/A/ AC/EC/F/FC/G/GC/ SFC/SG/SGC/SH/SHC/SJ/SJC (87-97)
Yamaha XJ550H/J/K/RH/RJ/RK (81-83)
Yamaha FJ600L/LC/N/NC (84-85)
Yamaha XJ600 (92-98)
Yamaha YX600 (86-90)
Upper: 25 x 43 x 11
Lower: 30 x 48 x 12
Yamaha DT50B, DT50MX, DT50U/W/A (88-90)
Yamaha RD50MX (82), RX50K/L/MK (83-84)
Yamaha YSR50T-E (87-93)
Yamaha YZ50G (80)
Yamaha JT1/JT2/JT2MX (71-72)
Yamaha RD60/A/B (73-75)
Yamaha YZ60H/J/KM (81-83)
Yamaha DT80LC H/J/K (81-83), DT80MX
Yamaha GT80A-G (74-80), GT1/GTMX80 (73), GTMXA/MXB/MXC 80 (77-79), MX80G/H/J (80-82)
Yamaha RD80LC/MX(82)
Yamaha TY80A/B Trials (74-75)
Yamaha YZ80A-K (74-83)
Yamaha HT1/HT1B/HT1BM90 (70-71)
Yamaha AG100B
Yamaha DT100A-K (74-83)
Yamaha LT2/LT2M/LT2MX/LT3100 (72-73)
Yamaha MX100A/B (74-75)
Yamaha MX100F/H/J/K (79-83)
Yamaha RS100B/C (75-76)
Yamaha RT100A (90)
Yamaha YZ100C/D/E/F/G/H (76-81)
Yamaha AT1/AT1B/AT1C/ AT1E/AT1M/AT1MBAT1MX/AT2/AT2M/AT2MX/AT3/ 125 All (69-73)
Yamaha DT125 All (74-81), DT125LC (82)
Yamaha IT125G/H (80-81)
Yamaha MX125A/B/C (74-76)
Yamaha XT125J/K/KC (82-83)
Yamaha YT125N (85)
Yamaha YZ125A/B/C/X (74-76)
Yamaha AG175B
Yamaha CT1/CT2/CT3 175 All (69-73)
Yamaha DT175A-H (74-81)
Yamaha MX175A/B (74-75)
Yamaha MX175G/H/J (79-81)
Yamaha TY175B/C (75-76)
Yamaha YT175J/K Atv(82-83)
Yamaha YZ175C (76)
Yamaha SR185H/J (81-82)
Yamaha AG200
Yamaha BW200N/S/ES/ET/ EU (85-88)
Yamaha TW200 (87-92)
Yamaha TYM200EX/EL (83-84)
Yamaha XT200J/K/KC (82-83)
Yamaha YTM200K/EK (83), YTM200K/L (83-84)
Yamaha YTM225DXK (83)
Yamaha DT1/DT1B/DT1CMX/DT1MX/DT1S/ DT1C/DT1E/DT2/ DT2MX/DT250A-F/DT3 250 (68-79)
Yamaha MX250A/B (73-75)
Yamaha TT/XT250G/H/J (80-82)
Yamaha TY250A/C/D (74-77)
Yamaha XT250G/H/J/K/KC (80-83)
Yamaha XT250W (89)
Yamaha YZ250A/B/C (74-87)
Yamaha DT360A/B (74-75),
Yamaha MX360/A (73-74)
Yamaha RT1/RT1B/RTM/RT1MX360 (70-71)
Yamaha RT2/RT3/RT2MX360 (72-73)
Yamaha YZ360A/B (74-75)
Yamaha DT400B/C/D/E (75-78)
Yamaha IT400C (76)
Yamaha MX400B/C (75-76)
Yamaha YZ400B/C (75-76)
Yamaha SC500/A (73-74)
Yamaha SR500E/F/G/H (78-81)
Yamaha TT/XT500C-H (76-81)
Upper: 25 x 47 x 15
Lower: 28 x 52 x 16.5
Kawasaki KL250D2-D8 (85-91), KLR250 (-98)
Kawasaki ZX400K1/K2/K3
Kawasaki EN450A1-A7 (85-91), EN450N
Kawasaki EN500A1-A6 (90-96), EN500C1/C2 Vulcan Ltd (96-97)
Kawasaki GPZ550H1
Kawasaki KZ550F1/F2/M1 (83-84), KZ550H1/H2 (82-83)
Kawasaki Z550G6, Z550M1 Ltd (83)
Kawasaki ZR550B1-B5 (90-94)
Kawasaki ZX550A1/A2 (84-85)
Kawasaki GPX600R
Kawasaki KL600A1/B1/B3 (84-86)
Kawasaki ZX600 Ninja (85-97)
Kawasaki KLR650/B2 Tengai (89)
Kawasaki KL650A1-A11/B2/ KLR (87-97)
Kawasaki KZ700A1 (84)
Kawasaki ZN700A1/A2 (84-85)
Kawasaki GP750R, GPZ750R/R1
Kawasaki KZ750F1, KZ750L3 (83)
Kawasaki KZ750N1/N2 (82-83), KZ750R1 (82)
Kawasaki VN750A2 (86)
Kawasaki ZR750C1-C4 (91-94), ZR750 Zephyr
Kawasaki ZX750A1-A3/E1/E2/ F1-F4/H1/H2
Kawasaki GPZ900R
Kawasaki ZL900A1/A2 (85-86)
Kawasaki ZX900A1-A3 (84-86)
Kawasaki KZ1000J1-J3/K1/K2/ M1/M2 (81-82), KZ1000P1-P17 (82-98), KZ1000R1/R2 (82-83)
Kawasaki Z1000K1 LTD (82)
Kawasaki ZG1000A1-A9 (86-94)
Kawasaki ZL1000A1 (87)
Kawasaki ZX1000A1/A2 (86-87), ZX1000B1-B3 (88-90)
Kawasaki GPZ1100A/S, B/S (81-82)
Kawasaki KZ1100A1-A3 (81-83), KZ1100B1/B2 (81-82), KZ1100D1/D2 (82-83), KZ1100L1 (83)
Kawasaki Z1100J/J2/Z
Kawasaki ZN1100B1/B2 (84-85)
Kawasaki ZR1100A1/A2 (92-93)
Kawasaki ZX1100A1-A2 (83-84)
Kawasaki VN15SE
Kawasaki VN1500A1-A9 (87-95)
Kawasaki VN1500B1-B5 (87-91)
Kawasaki VN1500A10/A11/C3/C4/D1/D2 (96-97)
Upper: 26 x 48.5 x 15.2
Lower: 30 x 50 x 14.4
Honda C250N (79)
Honda CB250 (Early Models)
Honda CB250RS (80-84)
Honda CBX250RS
Honda CM250T Rebel (82-84)
Honda GB250F/F2
Honda MVX250 (83-84)
Honda VT250F (83-86), VTR250 (88)
Honda CB350F/F1 (73-74), CB350G (73), CB350/ K2-K4 (69-72)
Honda SL350 /K2/K3 (69-73)
Honda CB360 (74-76), CB360GT (76), CB360T (74-77)
Honda CJ360T (76-77), CL360 (74-75)
Honda CB400A (74-75), CB400F (75-77), CB400TI/TII (78-79), CB400T (80-81)
Honda CBX400F
Honda CM400A/C/E/T (79-81)
Honda GB400
Honda CB450/K1-K7 (65-74), CB450T (82), CB450SC (82-86)
Honda CL450 /K2-K6 (68-74)
Honda CM450A/C/E (82-83)
Honda CB500/K1/K2 (71-73), CB500T (75-76)
Honda CX500 C/D (78-81)
Honda FT500 Ascot (82-83)
Honda GB500F/F2
Honda GL500/I (81-82)
Honda VT500 Ascot (83-84), VT500ED, VT500C/FT (83-84)
Honda CB550K/K1 (74-78), CB550F (75-77), CB550SC (83)
Honda CBX550F (82-83)
Honda CB650 (79-82), CB650C (80-81), CB650SC (82-85), CBX650ED/SCD
Honda CX650C (83), CX650ED
Honda GL650/I (83)
Honda VT700C (84-85)
Honda CB750K (69-78), CB750A (76-78), CB750F (75-78)
Honda VFR750C (83)
Honda VT750C (83)
Honda GL1000 (75-76)
Honda GL1000L (76)
Upper: 30 x 48 x 14
Lower: 30 x 48 x 14
Kawasaki KH250A5 (76)
Kawasaki KZ250A
Kawasaki EX350B1 (83)
Kawasaki KZ350A1/A2/B1 (81-82), KZ350B2/B3 (87-88)
Kawasaki KH400A3-A5 (76-78)
Kawasaki KZ400A1/A2 (77-78), KZ400B1/B2/C1 (78-79)
Kawasaki KZ400D/D3/D4 (74-77), KZ400H1 (79), KZ400S/S2/S3 (75-77)
Kawasaki ZX400D1-D5 (80-83)
Kawasaki KZ440A1-A4/D1-D5 (80-83), KZ440B1/B2 (80-81)
Kawasaki H1 500 C/D/E/F (69-75), KH 500A8 (76)
Kawasaki KZ500 (69-73)
Kawasaki H2 750 A/B/C (72-75)
Upper: 30 x 48 x 14
Lower: 30 x 52 x 17
Lower: 30 x 48 x 15
Yamaha FZR400R
Yamaha SXR400
Upper: 26 x 47 x 15
Lower: 30 x 55 x 17
Honda NSR250R/F
Honda VTR250 (89-91)
Honda CBR400R (87)
Honda CBR400 R/R
Honda NS400RF/RG (85-86)
Honda VFR400ZG/RG
Honda CMX450C (86-87)
Honda CX500TC (82)
Honda VF500C (84-85), VF500F (84-86), VF500FE/FIIE/FF
Honda VT500C (85-86)
Honda CBR600 (89-90)
Honda CBR600F (87-90), CBR600 FM-FR (91-97), CBR600H
Honda VT600CJ (87), VT600C N-R (92-94)
Honda VT600C/CD Shadow VLX (88-97
Honda CX650T (83)
Honda NT650 (88-89)
Honda NT650J Revere
Honda CB700SC (84-86)
Honda VF700C (84-87)
Honda VF700F/S (84-85)
Honda VFR700F/F2
Honda CB750C/F/K (80-82)
Honda CB750F N-S (92-95)
Honda CB750FA/FB/FC/ F2C
Honda CB750SC (84-85)
Honda CBX750FE/F2F (84-86)
Honda VF750C (82-83)(88)
Honda VF750CC/CD/CE/SC/SD
Honda VF750F (83-84)
Honda VF750 F D/E/F (83-85)
Honda VF750FD
Honda VF750S (82-83)
Honda VFR750 (90-93)
Honda VFR750F/F2 (82-87), VFR750F L-S (90-95)
Honda VFR750FG/FH/FJ/FK/ FL
Honda VT800 (88-89)
Honda VT800C Shadow(88)
Honda PC800 Pacific Coast (89-98)
Honda CB900C (80-82), CB900F A/B/2B/C/2C (80-82), CB900FS(94)
Honda CBR900RR (93-98)
Honda CB1000C (83), CB1000F S (95)
Honda CBR1000 (87-93)
Honda CBR1000F (87-88)(90-96)
Honda CBX B/C (81-82)
Honda VF1000F (84-85), VF1000FE/FF/F2F, VF1000R (85-86)
Honda GL1100 (80-83), GL1100C/AC/DC/IC, GL1100D2D/AD/A/IA/DA, GL1100RB/RC/D/ID/DD
Honda VF1100C (83-86), VF1100S (84-85)
Honda VT1100C (85-89), VT1100C R-S (94-95)
Honda GL1200 (84-87)
Honda GL1500 (88-91)
Honda GL1500 AP-AR (93-94)
Honda VTX1800C (02)
Upper: 26 x 47 x 15
Lower: 26 x 47 x 15
Honda CR80RL-RR (90-94 )
Honda CR125R (82-89)
Honda NX125 (88-90)
Honda XL200R (83-84)
Honda XR200R (81-87), XR200RE/RF/RG/RH/RJ
Honda ATC250R (83-86)
Honda CR250R (82-89), CR250RE/RF/RG/RH/RJ/RK
Honda XL250R (82-87), XL250R E/F (84-85), XL250R J/K/L (88-90)
Honda XR250RE/RF/RG/RH/RJ/RK, XR250R N-R (92-94)
Honda XL/XR350R (83-85)
Honda XR350RD/RE/RF/RG/RH/RJ/RK
Honda XR400R (97-98)
Honda CR450R (81)
Honda CR480R (82-83)
Honda CR500R (84-89)
Honda XL500R (82)
Honda XR500R (81-84)
Honda XL600R (83-87), XL600RC/RF (85)
Honda XL600RD/LD/RE/RF/RG/V-VH(Transalp)
Honda XR600R (85-89), XR600RH/RJ/RK
Honda CB750F/K/L (79)
Honda CBX1000 (79)
More great information inxs :thumbsup:
Its one of those lists I just know Im going to need one day but probably wont remember where I saw it when I do :laugh:
KevC, just bookmark this page (or add to favorites) :thumbsup:
Most lists like these come from ebay or other product sales pages for bearings, clip-ons or fork seals. They were probably copied from someone who copied them from someone who copied them from someone else. So to try to find the origin may be damn near impossible and to give credit to one person or page might just be giving credit to someone who also just copied them. :shrug:
Needless to say, I doubt anyone will take the time to verify the accuracy of the entire list so use it with a little caution. If you're eyeing up a certain model for a fork swap into your stock triple trees, one easy way to verify they are actually the size listed is to find fork seals for the forks you plan to use and verify the inside diameter of the seal.
I can add a little to this. I'll try to keep the format the same.
FORK TUBE SWAP 35mm
35 Honda CR-80R (87-95)
35 Honda CR-125M "Elsinore" (76)
35 Honda CR-125M "Elsinore" (77-78)
35 Honda NX-125 (88-90)
35 Honda XR-200R (81-83)
35 Honda CL72 "Scrambler 250"
35 Honda CR-250M/M1 "Elsinore" (73, 75-76)
35 Honda MR-250 "Elsinore" (76)
35 Honda VTR-250 "Interceptor VTR" (88-90)
35 Honda XL-250 "Motosport 250" (72, 74-76)
35 Honda XL-250S (78-80 To 5204066)
35 Honda XL-250S (80 From 5204067 - 81)
35 Honda XR-250 (79-80)
35 Honda CL77 "Scrambler 305"
35 Honda SL-350 "Motosport 350" (72)
35 Honda XL-350 (74-78)
35 Honda CL-450 "Scrambler" (69-72)
35 Honda CB-450 (70-74)
35 Honda CB-500 "500 Four" (71-73)
35 Honda CX-500C "Custom" (81-82)
35 Honda GB-500 (89-90)
35 Honda GL-500/I (81-82)
35 Honda XL-500S (79-80 To 5104835)
35 Honda XL-500S (80- 81)
35 Honda CB-550 "550 Four K" (74-78)
35 Honda CB-650 (79-80)
35 Honda CB-650 (81-82)
35 Honda CB-650C (80 To 2009951)
35 Honda CB-750K (69)
35 Honda CB-750 "750 Four" (70, 72)
35 Honda CB-750A "750 Hondamatic" (76-78)
35 Honda CB-750C "Custom" (80-82)
35 Honda CB-750F "Super Sport" (75-78)
35 Honda CB-750F (79-80)
35 Honda CBX (79-80)
35 Kawasaki KX-80 G1/G2 (86-87)
35 Kawasaki KX-80 L1-L3/N1-N3 (88-90)
35 Kawasaki KE-175D1-D4 (80-83)
35 Kawasaki EX-250E1/E2 "Ninja" (86-87)
35 Kawasaki KE-250B1-B3 (77-79)
35 Kawasaki KZ-550H1/H2 "GP" (82-83)
35 Kawasaki ZX-550A1-A3 "GPz" (84-86)
35 Suzuki RM-80 K/L/M/N/P (89-93)
35 Suzuki RM-80 R/S/T/V/W/X/Y/K1 (94-01)
35 Suzuki RM-100 N/T/X (79-81)
35 Suzuki DR-125 G/H/J (86-8Cool
35 Suzuki DR-125 SER/SES/SET (94-96)
35 Suzuki RM-125 M/A (75-76)
35 Suzuki SP-125 G/H/J (86-88)
35 Suzuki DR-200 G/H/J (86-88)
35 Suzuki DR-200 SET/SEV/SEW/SEX/SEY/SEK1/SEK2/SK3 (96-03)
35 Suzuki RL-250 L/M "Exacta" (74-75)
35 Suzuki SP-250 Z/D/F (82-83, 85)
35 Suzuki TS-250 1 "Savage" (69)
35 Suzuki TS-250 B/C/N (77-79)
35 Suzuki GN-400 T/XT/XX/TX/TZ (80-82)
35 Suzuki TM-400 K/L/M "Cyclone" (73-75)
35 Suzuki GS-450 LD (83)
35 Suzuki GS-450 LF/LG/LH/LJ (85-88)
35 Suzuki GT-500 A/B "Titan" (76-77)
35 Suzuki RE-5M, A
35 Suzuki GS-550 LX/ LZ (81-82)
35 Suzuki GS-550 B/C/EC (77-78)
35 Suzuki GS-550 LN/LT (79-80)
35 Suzuki GS-550 LG (86)
35 Suzuki GT-550 J/K "Indy" (72-73)
35 Suzuki GT-550 K (KAYABA)/ L (73-74)
35 Suzuki GR-650 D/XD "Tempter" (83)
35 Suzuki GS-650 EX/EZ(81-82)
35 Suzuki GS-650 GLX/GLZ/GLD(81-83)
35 Suzuki GS-750 B/C/EC (77-78)
35 Suzuki GS-750 EX/EZ (81-82)
35 Suzuki GS-750 LT/LX (80-81)
35 Suzuki GS-750 TZ/TD (82-83)
35 Suzuki GT-750 J/K/L/M/A/B "Lemans" (72-77)
35 Yamaha YZ-100 G/H (80-81)
35 Yamaha IT-125 H (81)
35 Yamaha RT-180A/B/C (90-93)
35 Yamaha XT-200 J/K/KC (82-83)
35 Yamaha XT-250 G/H/J/K/KC (80-83)
35 Yamaha TZ-250 C/D/E (76-78)
35 Yamaha TZ-250 F (79)
35 Yamaha RZ-350 L/N/NC/NCII (84-85)
35 Yamaha TZ-350 /C/D/E (72-78)
35 Yamaha XS-400 J/K "Maxim" (82-83)
35 Yamaha SR-500 E/F/G/H (78-81)
35 Yamaha XS-500 C/D/E (76-78)
35 Yamaha XJ-550 RH/RJ/RK "Seca" (81-83)
35 Yamaha XZ-550 RJ/RK "Vision" (82-83)
35 Yamaha XS-650 D/E/F/2F (77-79)
35 Yamaha XS-650 SE/SF/SG/SH/SJ (78-82)
35 Yamaha TX-750/A (73-74)
35 Yamaha XS-750 D (77)
FORK TUBE SWAP 34mm
34 Suzuki T 250
34 Suzuki T-250 II
34 Suzuki TM-250 J/K (72-73)
34 Suzuki TS-250 R/J/K/L/M/A "Savage" (71-76)
34 Suzuki TC-305
34 Suzuki T-350 1 / 2
34 Suzuki TM-400 R "Cyclone" (71)
34 Suzuki TM-400 J "Cyclone" (72)
34 Suzuki TS-400 J/K/L/M/A/B "Apache" (72-77)
34 Suzuki T-500 1/2/3, T-500M (75)
34 Yamaha YZ-100 C (76)
34 Yamaha MX-125 C (76)
34 Yamaha YZ-125 C (76)
34 Yamaha DT-250 A/B/C (74-76)
34 Yamaha DT-250 D/E (77-7Cool
34 Yamaha DT1/1B/1S/1C/1C-MX (68-70)
34 Yamaha DT1E/1MX (71)
34 Yamaha MX-250/A/B (73-75)
34 Yamaha TY-250 A/C/D (74, 76-77)
34 Yamaha RD-350/A/B (73-75)
34 Yamaha DT-360 A (74)
34 Yamaha YZ-360 A/B (74-75)
34 Yamaha DT-400 B/C/D/E (75-7Cool
34 Yamaha MX-400 B (75)
34 Yamaha SC-500/A (73-74)
34 Yamaha TX-500/A/ XS-500B (73-75)
34 Yamaha XS1/1B/2/TX-650 (71-73)
34 Yamaha XS1/1B/2/ TX-650 (70-73)
I got a great deal on some new Sportster wheels and tires (16 and 21") and was so exstatic that I failed to think about hub width. I'm now stuck with whether or not to try and fit a Sporty triple/fork set up on my '81 hardtail, or to dump these and go with some other make of wheel (I really, REALLY want to use these wheels).
Any suggestions on the front end swap? The above info was great, by the way.
Confirmed
XJ750 36mm fork Triple tree fits XS650 frame
- have you tried mounting your tank Wally, to see if it clears too?...do the stops line up?
Yes i mounted a C tank, All Clear but no rubber mounted handle bar mounts
I wont be running this tank I plan to use a Yamaha TY Tank
xj 650 leading axel forks off the special model also fit wid a small amount of skimming off the axel.bike seems to benefit from slightly longer wheel base , also bigger dia. disc. is good.
Its a 1975 frame I got it with lots cut off
No centre stand brackets
No side stand bracket
threads of foot peg stemms cut of.
I will be putting back the side stand but not the centre stand.
This project is going to take a little time I think
This site gives a list of the bearings needed to swap forks with the xs
I could only get part of it to run, I think it's a massive list, though they don't take the length of the stem into account, just the bearing sizes,
