Hey guys,
So I tried my hand at the dead cylinder method after recreating retiredgentlemans plug ground and I followed the directions laid out in the guide , but when I would turn the fuel screw In or out from its .75 set point there was no change in idle weather it was screwed all the way in our out a few turns... I did turn the fuel off to the dead cylinder when doing this, should I have left it on ? Or am I not doing something right ? I even pulled my carbs off and cleaned them again, this time I took note of the Jets and the pilot is 45 main 127.5
Thanks again for all your help
It does not matter what you do with the fuel to the dead cylinder.
You said the engine only idles down to 1400 rpm. That tells me that you have extra fuel/air going to the engine via the pilot jet and the butterflys. That is why you see no change when you adjust the mixture screws. You have to eliminate this extra fuel/air mixture before the dead cylinder method will work.
First thing is that the butterfly on each carb must be able to close
fully. If the butterfly screws have been removed in the past, then the butterfly plate may not be centred in the carb bore.If not centred then the butterfly will not be able to close fully, i.e. the plate binds on one edge and stays slightly open. You will have to remove the carbs to check that.
Caution: In the next step, you must use a screw driver that fits the butterfly screws perfectly. If you don't, you will strip the screw heads. They are JIS screws, so a regular phillips does not fit properly. Its best to buy JIS screw drivers. I have had success by blunting the point of the correct size phillips, so it fits exactly into the head of the JIS screws, but that might not work for you.
Once the carbs are on the bench, back out the throttle speed screw, so that the throttle spring is forcing the butterfly closed. You should not be able to see light under the butterfly. If you can see light, then you will have to loosen the butterfly screws, and allow the plate to snap closed so that the plate is self alined in the carb bore. Once alined correctly, the screws can be re-tightened. Its wise to use blue lock-tite on those small screws.
With 1975 carbs, which I believe are not linked, you will have to follow the correct steps to be sure they are correctly sync'd.
Also while the carbs are on the bench, you need to try to wiggle the needle jet. It should not wiggle. If it does, you must replace the rubber O-ring. A bad O-ring allows extra fue/air, and a high idle results. The needle jet is just a push fit, so they can be tapped out for inspection.
Also, if you have any air leakage around the carb manifolds or the carbs themselves, the dead cylinder method will not work.
