• It's time to vote for the bikes you want to see in the 2025 XS650 Calendar! Vote here!
Getting the ‘57 beetle back on the road in 2024
In the posted photo, is it just by chance the safety wire holes lined up, or were the bolts tightened until they lined up? I noticed as I work on this car, the absence of torque specs that you’d normally see when working on more “modern” vehicles.
That is a good question! I find it questionable that any random group of three bolts if all tightened to the same torque they would end up in a nice neat alignment like those.
Thought I'd sneak this in here...
Flaking chrome, some brake asbestos, moly grease, heat til it smokes, breakfast of champions!
With @gggGary ‘s suggestion I made my own hub cap fry pan - a pair of vise grips worked well for the handle. Eggs were a bugger to remove as they stuck to the rust. Lots of bacon fat and I was able to deep fry the eggs. Polished and first hub cap and is back on the car. Brake fluid reservoir is back to the car, coated with POR15 which should be brake fluid resistant. First backing plate ready to go back on. Issues encountered on the install with clearance problems between the back of the drum and mounting bolt heads. Safety wire may be an issue too. Stay tuned.
Front brake drum cleaning day. On the rears I used wire brushing, electrolysis and Evaporust. The fronts still had the bearing races in them so I needed to be careful I didn’t mess them up with one or more of my processes. I got my angle grinder and a couple of twisted wire, wire wheels and removed rust that way. They came out pretty good. The rust inside the drum will have to stay. I’ll visit my friend this week to get the drum friction surfaces cleaned up.
Both drums appear to be OEM VW parts but I was surprised how “rough” the surfaces were. It looks like they were cast and roughly ground to shape.
I attempted to safety wire the one side too. Doesn’t look real nice but should do the job. There’s red Loctite on them too.
More beetle porn.
- brake drums painted with POR15
- repacked bearings and new grease seal
- removed RF fender to install new beading (rubber trim gasket between body and fender)
- removed 4 broken (rusted in) 6mm running board mounting screws (welded nuts to broken bolts)
- “painted” bare metal fasteners with ACF50
- torqued all fasteners on RF suspension
IMG_4371.jpegIMG_4373.jpegIMG_4377.jpegIMG_4354.jpegIMG_4358.jpegIMG_4345.jpegIMG_4368.jpeg
What seemed like a simple task, turned out to be hours of work. The factory jack for the car was rusted to the point that it was inoperative. I thought s simple disassembly and cleaning was in order. Although thr mechanism looks quite simple, it wad s real pita to take apart and getting it back together again. Here’s the finished product.
View attachment 324025View attachment 324026
It’s nice you saved that original equipment, and those new emblems you got from @kshansen are the icing on the cake! 😉
