hotrdd
XS650 Junkie
I need some help. I went to attach the Speedo drive unit today and I can't seem to get it to sit in the correct spot. If I rotate it so it points towards the back of the bike then the cable nut hits against the fork tube. And if I try to shim it over the brake rotor is hiting the side of the brake housing. This is the first time I've really tried to get the front fork pieces all put together. Are these even XS650 forks? Are they on the bike in the correct direction or do I need to switch the sides? Should the brake caliper be between the fork and bike frame or out front? Hope someone here can help.
