Want to keep the dust down use something a bit porous behind the buffer. Hession sacking, calico or shade cloth.
Catches a lot the dust and cloth particles.
Sorry for hijacking your thread Leggers, deleted my posts. Hopefully, Bosco will do the same.
I peaked and thought both your and Bosco's posts were right on point....This was my one question, These have a clear coat on them that many people have to take the coarse grit to in order to remove if not using paint stripper right? On other bikes, I have removed faded clear coat with jet paint remover, then started sanding/buffing. However on the other bike I did, I did not polish cause it would look funny the way the rest of the bike was. My xs650 is in better shape so polishing is on the table.I like to start with paint stripper and then black (coarse) buffing compound on the coarse buffing wheel, switch to white on the soft wheel done, no paper needed. A set of 4 takes about 1/2 hour. I have a Harbor Fright 3/4 buffer and it's the bomb for some buffing. I want to go up to a bigger buffer but am waiting for a "deal". Various grades of coumpound work but you need to keep wheels and compounds separate. Great video! I prefer a full face shield when using the buffing wheel, the compound filled cotton fluff the wheel sheds are not good for eyes OR lungs.
What’s the best way to get the new stuff off? As suggested above paint stripper? Can’t get the nasty stuff up here anymore. Is it available in the US? Will vapour blasting remove it? Thx.the clear coat changed in the mid seventies, the older stuff, lacquer mebby, comes off easy, the newer stuff, some sort of poly mebby, is much more stubborn.
I think I recently did the "tough stuff" on two '81 Hondas. I used the eco friendly citrus stuff. Applied a heavy coat with a brush before going to breakfast, then another heavy coat on top of the first before going to lunch. It scrubbed away with Scotch-Brite and a hose about two hours after last application. My covers were in bad shape with the deep black spots, so the Scotch-Brite was a good start. Worked well, sausage biscuits and cheeseburgers at McDonald's didn't hurt.What’s the best way to get the new stuff off? As suggested above paint stripper? Can’t get the nasty stuff up here anymore. Is it available in the US? Will vapour blasting remove it? Thx.
Thx. I didn’t think the eco friendly stuff would be so effective.I think I recently did the "tough stuff" on two '81 Hondas. I used the eco friendly citrus stuff. Applied a heavy coat with a brush before going to breakfast, then another heavy coat on top of the first before going to lunch. It scrubbed away with Scotch-Brite and a hose about two hours after last application. My covers were in bad shape with the deep black spots, so the Scotch-Brite was a good start. Worked well, sausage biscuits and cheeseburgers at McDonald's didn't hurt.
Wonder what would happen if you fully immersed the part in acetone for 24 hours. One thing for sure is your walker would be much lighter.Acetone usually makes a pretty good coating softener.
