The nylon was temporary lol, I just don't have the filters. The guy before me took em off. Can I just leave this tube open?Crankcase breather. Normally hooked up to the stock air boxes you no longer have (Looks like replaced by nylon stockings ).
Dude...It appears you're missing the detent bracket that holds the choke on .....
I've made the mistake of tryin to use panty hose material for an air filter. My experience was that it will not pass enough air for the engine to rpm properly.The nylon was temporary lol, I just don't have the filters
I'm confused and still learning. I mistakenly thought the one way valve as 5T has shown before was just to prevent any risk of something going back into the crankcase. It will also have the beneficial effect of reducing crankcase pressure? This is because the crankcase is no longer ingesting air through those vents?Some sort of one way valve on the crankcase vent so the crankcase runs at reduced pressure is a popular modification on these and many other parallel twins.
I'm shocked @5twins didn't mention that.
I believe that in theory it would create a bit of vacuum in the crankcase. 5T had commented on this in a previous post.Ok, so another question, with these check valves installed on the vent tubes, does the crankcase not eventually create a vacuum which could be a bad thing?
Obviously you guys have this sorted; I'm just trying to fully understand it.
