MadMax1996
Yesterday I had swapped my failing BS38 carbs for brand new pre-jetted Makuni VM34 roundslide carbs. The fuel is now running through 2 fuel lines - each going tank to carb separately with shutoff valves and fuel filters in between. It seems to be running well enough to head down the road although I'm quite certain it could be tuned a bit better. It now has a tendency to backfire while either idling or rolling off the throttle. I'm hoping a good tune up with the correct pilot and main jets will fix the issue. Another new issue that the new carbs seems to be responsible for is an unpredictable throttle hang. I wonder if that has to do with my throttle cable not being long enough or if the slides are getting struck before eventually sliding back down.
