Beta version of bobbed front fender. Approximately 3 inches off both ends.
I am fitting some pieces onto the new handle bars, the front fender and the cam end covers. I want to locktite each piece but may need to adjust a little later. Does the blue locktite "shear" or "smear"? That is, is the locking function destroyed ,"shear" when you loosen to adjust or does it"smear" and retain its usefulness when you loosen and retighten?
Does that brace clamp over the rubber, below the rubber, or is the rubber trimmed to accommodate the brace?You'll be happy you've installed a fender because with the single disc, this fork really needs bracing of some sort. Adding a dedicated fork brace will help even more .....
I have the privilege or curse of living in a region settled by Germans and Dutch in the mid 1800s. An awful lot of straight property lines divided by straight county roads. A few interesting roads follow geographical features, but not many. I did alot of "knee dragging" curves riding in the foothills of Southern California 30 and 40 years ago and had a riot doing it. Now I will enjoy rather sedate riding enjoying the power band while not setting speed records. When I co6e across a brace I will add it.Absent the fender, any fender really, the bike looked like it had stretched forks. Nothing against choppers, but, not my style. And, I plan on fair weather riding mostly so protection is not paramount.
YouPorn.com is also a free source for lubrication technique information.Replaced the clutch cable this week. I hung the new one from a garage door track overhead and smeared 20W50 on the exposed cable. I used the dip the finger in the oil and rub it on the cable method.. Google it or go to the KY jelly website. Repeated a couple times. Google it or go to pornhub. When oil was dripping out I removed the sidecover. Sorry, no dirty pictures. While open I counted 18 teeth on the countershaft sprocket(and a clean cavity in the enclosed space) so a 32 tooth rear sprocket is on hold. NEW M/C bleeding is slow. I get a little movement pulling the lever, then nothing unless I wait 15 minutes. Mighty Vac just pulls air around the nipple so I will just have to exercise patience (laziness?).
