This section deals with the earlier B type regulator. It's written by 5twins. So, take it away 5twins....
OK, here I'll talk about the 'B' type regulator needed for the '70-'79 charging systems. There was a change in the 650 charging system in 1980 and it had to do with how the brushes were wired. On the '70-'79 systems, the inner brush is grounded full time to the stator housing through it's mounting screws and the outer brush is fed regulated power from the regulator. The 1980-on systems are sort of the opposite. Their inner brush is fed constant power from the harness (switched on and off with the key) and the outer brush is fed a regulated ground from the regulator. So, that means 2 different types of regulators are needed. As Jim discussed above, the '80 and newer systems require a ground switching type 'A' regulator. The '70-'79 systems require a regulator that switches or regulates power to the outer brush and that is called a type 'B' regulator. The most common one we use is the VR115 from Standard Motor Products. Many other manufacturers make this under a different part number and I'll list some later.
Now, this is a regulator only, not a combined reg/rec like the '80 and newer models used. The '70-'79 models used a separate rectifier. The same Windy Nation rectifier Jim used above can be used as a replacement. You can mount the VR115 in the same spot as the original regulator on the '74 and newer models. I'm not sure about the '73 and older models but it can probably be done as well .....
Only one mount will align with an original so a small triangle-shaped adapter or extension plate will need to be made up to reach the other .....
There was a small issue with the lower right mounting bolt in the pics above. It stuck out too far and hit the side cover so I simply flipped it around. The bolt head was still a bit close so I put a button head Allen in .....
Wiring it up is pretty simple. The black and green wires from the VR115 will match up to the same colored wires in the 650 harness. The red or orange and yellow wires on the VR115 get combined and connected to the brown wire in the 650 harness. The VR115 harness is very short, way too short to reach up on top of the battery box where the regulator harness plug is. Instead of cutting the VR115 plug off and soldering extension wires on, I simply make up a little jumper harness .....
The regulator end gets 4 individual spades that are plugged into the VR115 plug .....
To keep them in place, I install a couple cable ties .....
On the harness end, a matching plug to the harness is installed and I make the transition from 4 wires to 3 by combining the red (or orange) and yellow wires on one crimp .....
The extension harness is routed behind the battery box up to the regulator harness plug .....
And that pretty much covers it. Here's a list of some VR115 substitutes from other manufacturers, same regulator just under a different part number .....
GRX-528 Motorcraft (Ford)
VR 1010 NAPA Echlin
VR727 Wells
1V1033 Airtex
C622 AC Delco
VR-1760 Ace
VR291 GP Sorensen
R292 BWD
KVR179 Borg Warner
The silver one pictured above is the NAPA VR 1010 .....
