Starter Gear Fix!
Below I documented the fix for the slipping 4th starter gear. I want to add the original poster/author is below. All I did was test and post pictures to what he is writing about. I applied this fix years ago to a kick starter spring the same way with success.
The reason why the starter slips and spins out because the spring has lost it's tension or was never set properly. This is what I found.
The spring has to be at 6 pounds. I found when it gets to 4 pounds it slips. I tested this on 3 other bikes. They were all at 4 pounds that slipped, new aftermarket-used aftermarket OEM or otherwise. Just takes 2 pounds difference.
This is what happens to the gear when the spring is at 4 pounds pressure.
This is a fish scale I bought at Walmart for $15.00. I'll keep it and use it to adjust the steering head.
Here is the factory spring tension rate
I have gotten two of Mikes stater kits for 2 of my bikes and one worked fine and the other just spun. This is what I've found on the adjustment. You can only squeeze the spring in a vise. No matter how hard you squeeze you only achieve 6 pounds. So if you don't have a scale you will be in spec. Just don't over squeeze on the vise and disform the spring.
Here is what I've also found. On the left is Mikes spring. Notice the flat sides to fit the new gear. To the right is a OEM NOS spring, it's fatter-just not grinded flat. When I put a NOS spring on Mikes gear you only get 4 pounds. If you squeeze the spring you get 8 pounds so that is the best set up. *Note* if you put a OEM spring on a OEM gear you will only get 4 pounds, the spring has to be bent in a vise.
You really can't bend it on the bike and not take it apart this this.
OEM part #
Below is a post from the author with his fix I just documented and tested. This will fix the dreaded starter problem. You could probably just remove the slipping gear and squeeze the spring and you would be fine.
#Electric starter problems on the XS650 are very common, and almost always due
to a non-functioning #4 gear, the one that slides down the bendix helix and
engages the ring gear on the flywheel. Symptoms are a starter that does not
engage, a starter that just grinds ineffectually, or a starter that kicks out if the
engine does not start immediately. The usual remedy is to replace the gear
complete with it’s spring clip, but there is an easy way to fix erratic and non
functioning starters without changing the #4 gear, even if the gear is showing
signs of severe wear.
When people remove the offending gear it is often badly worn, and they
assume that is the reason the starter does not work. But exactly the converse is
true.
IT IS NOT A CASE OF THE STARTER NOT ENGAGING BECAUSE OF A
WORN #4 GEAR. THE #4 GEAR ONLY WEARS BECAUSE THE STARTER IS
NOT ENGAGING.
One will find in removing non-functioning #4 gears from an XS650 that there is
still lots of tooth left. Now the bendix on a car will continue to engage till the
teeth are completely snapped off, and even then will turn the engine jerkily.
One usually changes them to avoid damage to the ring gear on the flywheel,
rather than because they won't engage. It’s not the worn teeth on the #4 gear
that prevents engagement. The reason the starter does not engage is because
of the spring clip on the #4 gear losing it's tension. The manual calls for about
5 lbs tension required to rotate the clip in it’s groove on the gear. The tension
found on the new ones can be up at about 8 lbs. You will invariably find that
the tension required to move the clip on non-functioning starter gears will be
down to about 2 lbs or less. This can be measured using a fishing scale.
What happens is this.
Because the # 4 gear is light and does not have enough
inertia (resistance to being rotated from a state of rest), Yamaha designed in the
spring clip to increase the inertia. This restrains the gear from turning on the
bendix when the bendix shaft is initially rotated by the starter motor. So, as the
bendix rotates, the helix on the bendix shaft forces the gear down the shaft and
into engagement, because the gear will slide before it will turn. Once it gets to
the end of the bendix, by which time it is fully engaged with the flywheel ring
gear, it has no option but to turn, it has nowhere further to slide. When the
spring tension in the clip is too weak, there is not enough restraint, so instead
of the gear resisting turning, it just spins with the bendix shaft, does not move
down the shaft fully, and is not forced into engagement. It goes down just far
enough to grind off it's teeth against the flywheel ring gear.
All that is necessary to get a starter gear working, no matter how worn the teeth,
is to bend the clip so it gets back to a minimum of 5 lbs required to move the
clip.
All that is needed to do is drain the oil, remove the kickstart lever, brake lever,
foot rest, and disconnect the tach drive cable at the side cover. Then remove the
right hand side cover. The best way is then to remove the clutch basket and
dismount the #4gear from the bike. I haven’t yet tried to do this fix with the
clutch still mounted on the bike and the #4 gear in place, but this may well be
possible. I am pretty sure that on the newer units where the loop of the spring
clip bears against the floor of engine case the that the loop will be visible just
under the forward lower edge of the clutch assembly, and you will be able to
reach in and do the following without further disassembly. On the older units
with the clip with the skinny loop inside the recess in the crankcase, the clutch
will definitely have to be removed and the gear dismounted. In any case, either
way, just use a heavy pliers, like a linesman's pliers, or a Visegrip, to squeeze t
he loop of the clip closed so it bends a little and the clip then grips the gear
tighter. If you do remove the gear from the bike, lever the clip off the gear
using a screwdriver, squeeze the loop of the clip in a vise, and remount it on
the gear. Check the tension with a fishing scale, if it is less that 5 lbs squeeze
the loop a little more.
You can test it immediately, even before remounting the clutch. Pull the spark
leads so the oil-empty engine does not start, and hit the starter button. I bet your
starter will now work, no matter what the wear is on the #4 gear's teeth.
Farrell
My bike is 1979 by the way cheers
This is where my clip fits on my ‘76.
Around 1975, the drag clip was updated and the new one was made from heavier wire. It wouldn't fit in the original groove any more so it was positioned just to the right of it.
I'm guessing it's post count done by the forum software. I see you're presently a first class butcher. I don't know how many posts you need for the status to change. That's configurable by the site admin.
The newer clips are too wide to fit in the slot.
Bill
Yep thanks, I’m actually glad I tuned in to this thread as my starter is actually working ok, it’s overrun that I’m experiencing and now having done a bit more reading i discover that the overrun is related to a relay that should shut off the starter when the bike starts. So yeah my clip is bracing against inner casing as it’s the beefier clip and now I’ve just saved pulling my clutch when I don’t have to, it’s the relay that I will be checking, many thanks, again great info on here 👍👍
OEM part #
true.
NOT ENGAGING.
clip.
Farrell
Gary between yourself and farrell I really like what you did here. Leaves one feeling satisfied there's a decent fix and not have to remove all the bits and pieces after every ride. I just replaced the old one I had because I tightened the clip to what I thought was too much. I know I'll have a back up now at least. The new one I'm still gonna remove it and snug that clip a little before I put the motor back together. Fantastic! Thanks for all your efforts.
I’ve replaced and adjusted things as best I could and occasionally still get the annoying “run on” sound. I live with it and consider it part of the old bike’s character.
Yeah to be honest it works fine and I only really use it when I get the occasional cut out at lights. Yeah I suppose it is what it is 🤷‍♂️
So, what does it mean if, after doing all of this, the starter problem still exists? Do I need to replace the flywheel? See photo.
Are there instructions, videos, etc., anywhere that I can follow to replace the flywheel?
Any recommendations on where to buy a new one?
That gear doesn't look too bad to me.
Have you tested the starter using the bikes electrics?
Fault mat be there.
Hi JOHNDADDY,
Thanks for responding. I am not sure how to test the starter. I mean it "works"... it responds when I press the start button, and the engine will turn over once in a while when the bendix gear engages. It's just that most of the time it does not engage and just makes that horrific grinding sound.
Do you have other suggestions?
Hi JOHNDADDY,
You need to bend the clip on the starter gear. Lots of info on this in the forum. Search function should help you find it. I can look later.
Oh yeah, I know all of that, and have read all of the threads. I've done all of it, both with the original clip and the newer heavier one. I've replaced the bendix gear as well with the kit from MikesXS. That's why I am wondering about the flywheel. Thanks.
Was curious if you were getting enough amps at the starter through the bikes electrics.
If the starter sounded strong and the gear threw out with a good slap.
If the spring is right it may be weak electric.
Is it on the bike now? If it isn't I'd make up a good set of jumpers hook it up and test it.
See if it behaves the same way every time. Might help eliminate bad contact in the starter button
or point you in the right direction. I'm sure others will chime in with more ideas.
Good point. Worth checking out. All too often we immediately assume it’s a weak spring clip.
Had the click of dread on my other bike.
That one has a solenoid. Took it apart cleaned the connections (dremel)
blew it out and sprayed with contact cleaner. It was filthy.
Works great now. Never been it the starter on the 650 but I'd
be willing to bet it looks the same. A clean out and touch up or replace the brushes
might be in order.
So, I read/skimmed this entire thread again and came to the conclusion that if you have a starter issue, go to page #1 and start from there. I did actually fix my starter gear by using the complete gear and spring from a 75. It tested at +6#'s and I'm happy.
But, I was actually skimming to find where someone, (5Twins I think), mentioned to be careful not to allow the shaft #10 to slide out and release from gear#12. Well, I had to remove the gear#11 to slide the starter gear assembly out for lubrication before I locked it in, and shaft#10 slid out with it. I almost cried. There was no way I wanted to remove the engine again and remove the bottom case just to put that stinkin gear back on!
I did get it on without much difficulty. Although I do remember that it was difficult to get it on the shaft when everything was open.
Does anyone really want to know how I did it? You can say no or just not respond, but I impressed myself!
Need to know; the "flywheel" is the complete pressed together crankshaft assembly.
And yeah yours looks fine.
I'd like to hear this!
