Ritchie
Without knowing what carbs you have...........
On the other hand you don't turn the idle screws IN you lightly seat and turn them OUT. That said 2 turns out should let it run on nearly any carbs, then work towards the best idle with no fall off when you crack the throttle. Work both screws together till it runs best then you can mess with one at a time to see if it will do even better. Use the dead cylinder method, keep a grounded plug on the disconnected wire (keep track of where you are on both screws)
Thanks gggGary. Thats all I wanted to know.
