Hi @RaymondCheap, reliable and readily available. I bought a Fiat reg/rec for my XS650.
which fiat reg/rec did you use?
it’s the only part of the system I have not changed.
Great, Thank you for the leads RaymondAds, couldn't find the invoice, the supplier must not have sent a paper copy, but it's this one: https://www.ebay.co.uk/itm/273616060566
and it might be worth taking a look into the annals (!) of Miss November's shady past, where I was given invaluable assistance by @Paul Sutton and @5twins - read this https://www.xs650.com/threads/miss-november-xs2-tribute.55057/post-641793 and some following posts for a discussion of Type A and B regulators and how to wire the unit. The Orange Peril had an engine and alternator swap.
The Fiat regulator is small, light, not very expensive and has done the job faultlessly since.
Shit... Where is the plug cap thread???Yes, that's the normal plug but it's getting hard to find because it was discontinued. All that's readily available now is the resistor version, the BPR7ES. If you go with that, you'll want to get rid of the resistor plug caps and just use non-resistor ones. You only want one instance of resistance in each spark plug line. That can be the plug, the cap, or the wire, but you don't want a combination of more than one.
No... there is a plug cap thread easily found in search I was just realizing my idiocy. (I have a lot of that) My '77 has an after market ignition that call for BPR& plugs and I have been using those on my 81 Red Bike with a stock Yamaha ignition. The "shit" comment begs the question that I wonder how many false signals I may have followed chasing jetting on the VMs and how I could miss such a simple wrong step.Good question Kevin. All it takes is for someone to be interested and engaged enough to make a thread. Not hard to do a search and there will be all the info needed on the first page. If you make one up i will link the thread to the the info sticky i made
https://www.xs650.com/threads/bp7es-plugs-discontinued.63924/Google NGK plug caps.... tons of info. These will get you started on the thread you're gonna do though....
...what oil should I use in my XS...?Google NGK plug caps.... tons of info. These will get you started on the thread you're gonna do though....
LOL!!!...what oil should I use in my XS...?
