theDQG
Do the forum's Google custom search on "advancer nut".
First 4 threads go into removing the Advance Timing Unit...
Thanks, I reviewed the threads and looks like I skipped a part. Good thing I read about using a punch to loosen the funky wheel knob that holds the governor in, rather than a screwdriver that would have bitten into the wheel.
As I'm removing the components of the motorycle, I'm trying to understand how each component works- the breaker points system and the governor's unit.
Found a good video that seems to explain the breaker points system, and while this is for a car, I assume that the concept remains the same, namely that the chief function of the breaker points is to induce an EMF in the secondary winding of the ignition coil which drives the volts up to the +/- 22,000 volts necessary for creating an arc in the sparkplug?
The governor unit is sort of a mechanical cruise control in that it maintains engine speed via weights on a flywheel in response to engine load, such as going uphill, correct?
My question is, how does this act in accordance with accelerating? If the bike is going uphill and the governor responds to stabilize RPM, and I decide to accelerate, does the governor back off? How does it work in regard to the act of accelerating?
