Badges- A turned or polished alluminium plate with Yamaha is script or Block?
Don't forget the idle adjustment screws and sync!Tell us more about how it stops when you turn the chokes off. Are you able to keep it running for a few seconds while you juggle with the throttle or does it stop straight away?
Float height? Low petrol in tank?
Sorry for including that last one, but many's the time I've had a cantankerous engine - reluctant to start or starts but won't keep running - on a new to me bike and a factor that does not help is wondering how much fuel is in there, does it need to go on reserve? So I slosh enough in to remove that variable.
I’m sure you did this correctly, but I’ll throw it out there just in case. You know the static timing on the Boyer has to be set on the full advance mark. Not the fire position. ( Note this photo indicates the retarded timing I run on my XS2)
If you ever run out of adjustment for the Boyer PCB at the left side of the camshaft you just need to loosen the magnetic rotor nut and turn the rotor a little. Then retighten. Setting the rotor in the optimum position requires 3 hands...
@WideAWAKE
Very sharp looking bike.
Lots and lots of cool features.
Great selection of colors and their placement on parts that create a cohesive and complementary
scheme. Well designed. Kudos.
Agree.Definitely gloss
