My guess would be the mileage was when it was performed and they left it up to the owner to decide the interval/mileage they wanted the next one performed at.
worst news is my LR swing arm is seized in the down position. I’ve tried jacking it and beating it (gently) with an 8 pounder but no movement. I’m soaking the joint in penetrating oil right now. Fingers crossed it’s not a huge job.
Thx Jim. I did remove the shock and no go.Don't discount that it could be the shock seized up.
Anything's possible, but I've never seen the torsion bar pivot seize up. Iirc, the bushing out there is a rubber doughnut (for road noise reduction). Can't really envision that seizing.
The gap between 31 & 29 isn’t huge. Long shot but if it sat for 50+ years in this position, could rust have formed between these bits “seizing“ it up? It’s quite a large surface area. I’ll remove the cap tomorrow and report my findings. Looking at the exploded diagram it seems very simple with little to go wrong.
Hopefully I won’t have to dismantle the front end but if I do I can measure the bars and let you know. Might be after Christmas.Just as a side question. Are you planning on removing the front suspension parts? Namely the front torsion bars.
Not sure of the 1957 but know some VW's have what looks like maybe 3/4 inch wide and 1/8 thick flat bars stacked up in the tubes for front suspension. What I'm looking for is how thick the bars are. I believe some models use different thicknesses, or maybe more than one thickness in one stack.
Might sound odd but there are some older California Sidecars that use sections of those VW torsion bars for their torsion bars.
Well, it took a few days to get that way....but takes a looong time.
I can’t imagine doing a complete restoration. Not for me anyway at this point in my life.Well, it took a few days to get that way....![]()
Looking good there, Bosco!Pretty pleased with the results but takes a looong time.
