Got one drum finished as well as one bearing / seal retainer. I’m learning quite a bit as I do this. I only wish I could keep the water warmer as I’m sure it’s slowing down the process. The distance between the cathode and anode makes a huge difference, if I move the part from the center of the pail, to a couple of inches from the anode, the current increases by at least 50%.
Frequent brushing really speeds up the process as
@gggGary advised.
The use of distilled water kept things much “cleaner” too.
@Jim ,regarding the startup of my charger - as mentioned in my previous post I had to boost it to get it started, however, after it has run for a while I can disconnect the cables, scrub the part and if I put it back in fairly promptly, the charger will start again without a boost. Is the electrolyte bath holding a temporary charge?
It’s been good entertainment with pleasing results. Now I have to get painting.
View attachment 256163View attachment 256164View attachment 256165View attachment 256166
