The shim (washer) I needed was about 1.5mm... but yeah, put it on the right side so it doesn't mess with sprocket alignment.
I'm going to shim it and go.We don't really know where that gap comes from. So the only "truth" is checking sprocket alignment. not a bad idea anyways.
A thought on squeezing "wide gap frames" down. A short distance in front of this pivot is a rigid cross member so when you start cranking, the two sides get \ / creating stresses, the pivot shaft almost has to bow, throwing all the machined surfaces into an ugly bind.
I first mentioned the need for shims instead of brute force here about 10 years ago. It seems to mainly be a later model special thing. But worth looking for before the breaker bar is applied to the end nut.
1.16mm ....give or take a hundredth or two. ...If one of you has the grease seal, I'd love to know how thick it is. I don't have a micrometer.
Shims inside the grease seal have a different mission. and are MUCH thinner than your washer.View attachment 209017View attachment 209018
As a reminder, that gap is 0.129". That washer is 0.113".
This is where I gave it up tonight. It's not going to go.
I checked the '79 frame I'm tinkering with. It has the same huge gap.
View attachment 209027 Here, the shim is shown inside the grease seal. If one of you has the grease seal, I'd love to know how thick it is. I don't have a micrometer.
My washer is 2.9 mm thick. The shim from Yamaha is of unknown thickness and about $8 ea plus shipping. I'll order from McMASTER-CARR as soon as I figure out what thickness to order.
I guess I'll be working on something else this weekend.![]()
That'd be my guess too.some time with a file to remove the ridges from the edges may be all you need for it to fit in.
I need to fill .129 and the grease seals took .091.16mm comes out to .045"
Thank you! I need a half a millimeter on each side. That should get it very close.
I’ll give that a go first.Got an extra grease seal? cut the rubber off and there's your shim. Will be about .005" too much, but that should make a snug, hand tight fit.
Blue wrench would make quick work of it.I’ll give that a go first.
I know, but they don't say how thick they are. They're also about $8 ea and likely take 6-8 weeks to ship.Yes, the shims shown in that parts diagram are for shimming the width of the swingarm w/ bushings installed in relation to the length of the pivot tube. You want the pivot tube just very slightly longer than the swingarm w/ bushings. If it's too long, once clamped in the frame, the swingarm will have side to side play on it.
Marty; see here. https://www.xs650.com/threads/insta...shings-and-setting-sideplay.51077/post-584157I know, but they don't say how thick they are. They're also about $8 ea and likely take 6-8 weeks to ship.
