She..... Jackie is a she.It’s taken all day to charge that battery mainly because my first charger that was hooked up decided to give up the ghost at some time during the day so I had to hook up one of my maintainers. It’s almost there but it’s an AGM battery and I need to make sure it’s fully charged. I took the time to work on some of the other parts I need(it never seems to stop) and am making somewhat progress. Of course Sumo rubber only had one side cover rubber in stock and zero of the Airbox connectors I need for the XJ. Jackie has been very accommodating and told me that since the parts were not available from his UK supplier he would order directly from his Japanese source. Seeing as how none of the rubber bits I need is causing an issue I want to see what he tells me about a timeline. I ordered my 5K spark plug caps off Amazon and they don’t seem to carry an inexpensive wire option so I’m going to check the Marine store tomorrow for wire BTF. If not I found a set at TSC with 6 different length wires with copper core for tractors. I’ll cut them anyway so that may be an option.
I would have preferred the carb side be snug because that’s where the weight of the carbs are supported. I heard the same comments about the fit for my GT750. Hopefully with the clamps snugged up they will be fine.I planned on trying that but left the key on last night and am changing the battery now. On another note I finally spun that valve in a drill and yep, wobbler…
The Airbox side is snug and the carb side is a tiny bit loose. When I get the spring installed I should know better about that side. How should it fit, snug both sides?
Jim if a condenser is shot, will the bike still run? Just curious.
