Jim,
Interesting test. And good info that the Coil resistance changes as it warms up.
I expect 2 things change when on the bike. Rotating it may cool better, but being right next to the engine and being covered, it could be heating up even more.
So, I bench tested the regulator.
Variable Power supply from Black to Brown.
Volt Meter from Brown to Green (Rotor Coil Voltage)
With the regulator removed, the green voltage will drop to 0. (if it was in the bike, it would reduce to about 1/2 to 1/3 I think)
My regulator was moving off the primary contact at 16.5V. WAY too high.
There is an adjustment screw on the bottom (as its mounted on the bike) which would make it really hard to get to when mounted.
There is a nut to set it tight. loosen the nut then go CCW to weaken the spring and thus make it trip sooner to reduce the voltage.
Just to put this one on the safe side, I set it to 13.8V. Tightened the nut, then tested again for 13.8V. That is not necessarily how high the battery will go but the trip point to change the voltage going to the Rotor and reduce output. Running on the bike would be needed I think to get a better indication.
This does NOT appear to be in the Service manual I have and I feel a weak aging coil causes this to come out of adjustment and will only get worse as the coil weakens further. This also can likely be temperature dependent and act differently in the summer or winter. Since this is not direct to the battery but the Brown wire, I can also imagine if you have poor connections in various location and the Brown wire circuit is not at battery voltage, it can make the battery voltage higher than the brown wire too and switch later as well.
So, this is what I'm going to go with for the sequence of events that lead me here:
- Bike ran fine
- Regulator Coil weakened over time and then did not properly lower voltage to the Rotor.
- This fried one phase of the Regulator
- This later fried the Coil on the Rotor.
- Owner put bike away for a period of time
- Friend purchased bike for $300 several years ago
- Friend traded bike to me for gun parts
- I fix Bike
This is all academic cause I have a VR115 due in today.
