Hi,
OK, I've got a couple of issues that someone may be able to help me with.
1. The electronic tacho doesn't want to show anything. The LCDs work during the self test and I've seen one LCD flicker, so the screen appears to be ok. All other indicator lights work fine. I've connected the RPM signal lead to the negative pole of the coil and a digital multimeter shows some voltage (11V AC) on this wire which seems to indicate a pulsing 12v signal at idle. Nothing happens on the screen. Only time I've seen a single bar flicker is after coiling the signal wire around the HT lead several times. Anyone tried anything else? Filters, amplifier circuits?
2. Carbs - The bike starts first kick and idles fairly smoothly and then sometimes dies after 3-4 minutes. The idle works best when the air mix screw is 0-1/4 turn out, suggesting that the pilot jet is too small and needs to be richer. (bike dies if I screw air mix screw out past 1 turn) However, the plug and piston are wet and the inlet manifold feels and looks wet also, suggesting that the bike is running very rich. Anyone seen this before. I've ordered pilot jets either side of the 25 jets I'm using but a bit confused as to which way to try first. Both float levels appear ok, but I'll double check the measurements. Thought maybe float level might be too high.
Any ideas?
