I do not think so. That kit is only shows up if you put in 74 or newer.I am going to tear the engine back down and install a 743cc kit. I have the cylinder (thanks to Jim) without sleeves. Now all I need is the high dollar stuff. Sleeves, pistons kits, and gaskets.
Does anyone know if the Piston Kits from XS650Direct.com will work on the XS2- 256 engine?
Only for the 74-up engines.Or this piston kit from yamahaxs650.com. I am not sure which ones to order.
Help please.
Bill
1974 and up.I am going to tear the engine back down and install a 743cc kit. I have the cylinder (thanks to Jim) without sleeves. Now all I need is the high dollar stuff. Sleeves, pistons kits, and gaskets.
This one on eBay said it was for a XS1 not a XS2.I also seen these on eBay but they are 1st oversize. No piston pins.
So if I changed the crank I could use the BBK for a 447 engine? Will the heads work?Just the crank. I also replaced the trans because the engine the crank came out of only had 10,000 miles. My engine 35,000 or so miles.
Yes....and buy BBK sleeves/pistons. It would be a little more expensive but it would keep the original look of the engine.
The BBK sleeves have a bigger OD than stock sleeves. The block would need bored for them. Doable. I would bet Yamaha had to do the same when they built the GS bikes. Even now custom sleeves are surprisingly low cost. My machinist had a boo-boo when boring my X75. He had to have a custom sleeve made in order to use my NOS Hepolite pistons. It cost him around $130 to have the sleeve made.Yes.
Bill, the dimensions for the jugs are in this thread. If the BBK sleeves match the originals dimensions.... I'd do it like Greg suggests.
I know the cam chains are different. I just rem that.If you put a 447 crank in it , don’t you have to use a cam from a 447 also? I thought that the gearing for the timing chain is specific for the 447 motor.
