Welded Frame, Bike wont start.
nikiforova
Illinois
Also, I havent said it enough. Thank yall so much for taking time out of your days to help me get this bike running again. Its my main means of transportation and the fact that yall are helping me proves gods infinite mercy. Anything less than infinite mercy would have thrown a brick at my head for being such an idiot. So thank you.
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Easy test on magnet (stock stator system); key-off, hold 10mm wrench between thumb and finger, let it dangle vertically close (1/2") to left cover in front of shifter. Turn key on. The wrench should be pulled into cover via magnetism.
gggGary
Behind the ears too?
XS650.com Supporter
Baraboo, WI, USA
:whistle:That's the electomagnet.
We've had magnets that energize the pickup coils seem weak. a bit of pull on a screwdriver placed on the magnet a decent test.
jpdevol
XS650 Junkie
XS650.com Supporter
26187
We can verify you coil connection to bike harness whenever you're ready (colors),
Need to know what wire colors (smaller 16ga wires) are present from coils or a pic of coils please
nikiforova
Illinois
So it pulls the wrench in from about a half inch away. My best guess tells me the magnets are probably okay. Is it common that welding the frame can cause damage to them?
jpdevol
XS650 Junkie
XS650.com Supporter
26187
All good there. That verifies (kinda) that pickup coil is seeing what it needs to. Coil connections? and you said you have 12V there on R/W wire?
nikiforova
Illinois
Here’s my coil and my harness wired to the gn250. I still have a white and blue and a white and green wire connected to the stock harness that now goes nowhere. Could this cause issues?
nikiforova
Illinois
Yep. Just soldered the old wires onto the mp08 and it’s giving me good connection. Reading 12.05 volts at the red wire and 3.1ohms as the primary
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Should be good there at coil. I don't think it matters on polarity, but orange is ground signal from TCI, R/W power 12V+.
I'm researching Wh/Gn and Wh/bu vs Gonzo.
Hi Bob! Gary send you? Gonzo help...
nikiforova
Illinois
Yeah just made an observation checking my pickups. They seem to be pretty good, 725 and 780, but what I did notice is that the bl/wh wire that I have plugged into the gonzo doesnt give me a reading, but gives me a ground for the other wires (orange, wh/gn). Would this mean that my wh/gn is my negative and the bl/wh is my ground and I should plug my wh/gn into the gonzo?
Edit, found this diagram and im inclined to give this a go. Its on the https://www.xs650.com/threads/gonzo-diy-tci-system.57694/ thread.
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Wait'in on jetmechmarty, I think he has one of these critters........
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
The two wires peculiar to the 82-83 bikes go to the sidestand switch. If the bike is in gear with the sidestand down, voltage is removed from the TCI. When you go from 8 pin to 6 pin, those are the two wires to be eliminated.
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Those extra wires are from sidestand safety switch and do not connect to Gonzo. I'm unsure ATM what to do to bypass that function
nikiforova
Illinois
Okay, pretty much both my pickup positives are coming from the wh/r
jpdevol
XS650 Junkie
XS650.com Supporter
26187
Fashion a temporary jumper from Blue/yellow to ground - see what happens
nikiforova
Illinois
Also to note, My side stand safety switch has never worked. Ive been able to start the bike with it down all day
