didn't go looking, I'll put it on today's agenda.Did you have time to find the two shocks that the green covers go to?
For shocks buying or building this is a must?
The problem is not the strap wrench. The problem is that it can't hold on to chrome. You need to wrap the chrome fork nut with:I need a good strap wrench. I ordered one but it was crap. What does everyone use?
Does this tool work on the 70/71 shocks?didn't go looking, I'll put it on today's agenda.
Will regular duct tape work?The problem is not the strap wrench. The problem is that it can't hold on to chrome. You need to wrap the chrome fork nut with:
3M
Super Tough Extreme Hold Black Rubberized Duct Tape
available at Lowe's. It's sticky and will stay on the chrome, and it's rubberized so that the strap wrench will stay on it.
It will assemble/disassemble Progressive Series 12 or 14. It works perfectly on my OE KYB shocks. It’s also inexpensive and safe.didn't go looking, I'll put it on today's agenda.
It's worth a try, but the strap might just slide off of the duct tape like it does on the chrome. The strap will lock on to the rubberized duct tape. Maybe if you tried roughening the regular duct tape with sand paper? Or put contact cement on it, and let it completely dry? Or tried both?Will regular duct tape work?
What is an air bully?a good soaking both rust buster and heat gun?
Got an air bully? through a wood block or such especially while twisting with the strap wrench.
No I have not. I will look again. Thanks.@BowlingSS I found them. ( Mostly) one spring missing, note how top clevis threads onto rod with a lock nut.
Have you seen an unchromed spring in the parts boxes?
I have one of those. Only used it a couple of times.View attachment 211254
But with a tool that has a saddle to fit the side of the collar it's just a big shaker/ loosener. Thought that tool was a normal thing but didn't see one at the usual stores. Guess I made the one I have out of some other tool for the impact pistol.
Great.Fond the remains of that spring.
I received my shock tool today. The eye is too small for the tool. I was thinking of grinding the tool to fit. Anyone have this problem?didn't go looking, I'll put it on today's agenda.
The upper mount is the same. I do rem reading this tool does not work. I will get you another shock and the two covers.Have you tried the upper mount? That's where the tool goes in.
