What engine is that? A Liberty Engine perhaps? Well done though.
... the detonation shows up if running around 3K RPM. If I am going faster say 3.5K or higher no problems.
This needs more discussion.Hey, dps650rider!
Ruh-roh.
That particular rpm raises the hackles on the back of my neck.
Old Delco distributor timing machine manuals had a warning about over-advance in what they called the "Detonation Prone Zone", the 2,700-3,000 rpm zone. No explanation, just something that mysteriously happens.
A mystery that I just had to explore.
Years later, playing with my engine simulator,
http://www.xs650.com/media/albums/dream.1680/
I found an interesting phenomenon occurring at around 3.000 rpms.
Warning, highly debatable stuff follows. I've never been able to get this idea across.
Difficult to explain, but it appears that, within that rpm range, the decelerative force of the piston as it nears TDC is equaled, then exceeded, by the combustion pressures (depending on throttle position), and the piston side-wall thrust (based on rod angle) reverses rapidly. And, this side-wall thrust does another rapid reversal just after TDC. These rapidly reversing side-wall forces create a kind of piston rattle, what folks call "ping of detonation", but is really a unique kind of piston slap, what I like to call "piston flutter". These side forces stress the piston at the ring grooves, potentially causing the top of the piston to shear away. My simulator shows this as a normal phenomenon, that "detonation" (as accepted by the masses) doesn't exist, and is easily avoided by just a little ignition retardation at that unique zone.
Honda mitigated this issue by having a 1mm offset in their pistons' wrist pin holes.
I incorporated the same in the Dragon.
What this boils down to is, check the amount of spark advance at that particular rpm. You may be hitting full advance too early. Remember the distributor spring kits of yesteryear?
In the worst case scenario, worn rod ends will produce serious rod knock at those rpms. Usually detectable by varying throttle, acceleration and deceleration, causing a change in the sound of rod knock.
Ok, now I'm going to flee before things get thrown at me...
The slot at the bottom of the sidecover. Left side is 40°. Right side is 35°I would like to check my timing and maybe even slot the trigger coil mounting in order to play with it, but a previous owner lost the timing mark that is ordinarily affixed to the bottom of the stator housing!
I suppose I can either extrapolate from top dead center with a degree wheel or maybe try to find another stator housing.
That said it doesn't knock or ping at any RPM and it isn't set up excessively rich, so I feel like I'm safe to keep running it the way it is.
It would just be interesting to know for sure...
Hmm....Interesting thoughts re. detonation, 2M, but it may not be an either/or kinda question. Bits of aluminum on sparkplug enamel is typical pre-failure evidence of detonation, and it's hard to see how shearing forces could put 'em there. Also, all of the XS650 piston holes I've seen were small (dime size or less) and looked to have been eroded rather than sheared--no sharp edges in evidence.
Several years ago, I set my XS1B ignition timing a bit retarded to improve my idle stability, reduce vibrations, and give a smoother and more docile power output to match my sedate 'old man' riding style. Then, after building my LED Ignition Timing Light, I reset my retarded ignition timing back to the factory spec of 40° BTDC full advance.
This new performance of the engine was awful. The idle became unstable again, but more importantly, the highway performance was alarming. To maintain 60-70 mph required much more throttle, power was down, vibration was way up, and my typical hot oil temps rose from 230°F to around 250°F.
Whut's goin' on?
Warning: *Ramble mode engaged*
The XS1 was developed in the late '60s, and held a respectable position in the early '70s. Fuels, oils, and sparkplugs of that time have changed, and we've had to adapt. I'm still catching up on this new world of low-octane gasohol, and its effects on vintage engines. Back in the late '60s - early '70s, gasoline was easily available in 98-108 octane, enhanced with tetra-ethyl-lead. My primitive 'oldschool' understanding of octane ratings was that the higher octanes had a higher flash temperature and a slower, controlled burn, a requirement of the high-compression muscle cars of that time. Folks thought that higher octane gave you more power, but the reverse was true. To get more power, you increased the compression ratio (C/R), which then required the higher octane rating. On a lower C/R engine, more power was realized on the lower octane (faster burning) fuels.
Fast forward to our modern gasohols, with octane ratings of 87-91. Which makes me think that these modern fuels burn faster, and need LESS spark advance.
A Google search of "ignition timing curve" and "spark advance curve" shows numerous charts where the vast majority of modern engines limit max spark advance to around 30° BTDC, with very few going to 35° BTDC, and rarely to 40° BTDC (for vintage engines).
Thanks to advancements in engine design technology, and associated analysis tools, a new perspective exists that may be applied to our vintage engine. For example, this pictorial of combustion chamber designs shows associated max spark advance values. Note the vintage side-plug hemi-chamber value of 40°-42°, versus the newer pentroof at 30° and less. Our combustion chamber is somewhat between the two, with its higher mounted plug position. This would seem to support reducing our full advance timing.
I'm not having much luck finding good comparisons of fuel burn rates, fuels of 45 years ago versus modern gasohols.
http://performancetrends.com/Definitions/Burn-Rate.htm
But, this somewhat summarizes my thinking of what's going on:
Energy density of gasohol is about 3% less than gasoline, requiring more throttle.
More throttle requires less spark advance.
Faster burn rate of lower octane rated fuels requires less spark advance.
A search thru this forum found recommendations from XSJohn (rip) of retarding timing about 5°, from this thread:
http://www.xs650.com/forum/showthread.php?t=2426
And, I found a post from grizld1 of his running a max of 38° BTDC. There may be more, like the recommended ignition timing setups for the track, but those would probably apply to the old days and vintage fuels.
For now, until I can do more exhaustive testing, these are the ignition timing positions I'm running:
View attachment 62032 View attachment 62033
This represents my modified current ignition timing curve:
So, I'm thinking that if you're experiencing poor highway performance, excessive vibration, hot engine, poor gas mileage, an ignition timing 'retard' of about 5° may help your condition.
Comments, guys...?
what ignition are you running? other details (a pic or 2) of the bike?This has been a really interesting thread!
If I could jump in here... my issue is that if I retard anywhere below max advance, idle becomes very difficult. I've tried bumping up idle speed but it hasn't helped. It frequently and intermittently dies at idle.
Any thoughts?
